ok frame and suspension experts...here is a head scratcher..... - Page 2
This is a discussion on ok frame and suspension experts...here is a head scratcher..... within the General forums, part of the Caferacer.net Forums category; That diagram doesn't apply here. That shows trail on a bicycle fork where the fork and neck are in the same plane and doesn't have ...
Results 11 to 20 of 28
  1. #11
    Senior Member o1marc's Avatar
    Sep 2012
    Dawsonville, Georgia, USA.
    That diagram doesn't apply here. That shows trail on a bicycle fork where the fork and neck are in the same plane and doesn't have triple tree spacing the forks out. All those angles change when you have triple trees. When moving the axle to leading or trailing both put the axle further ahead of the trees on a motorcycle than on the bicycle. Am I wrong?
    Move the center line of the neck to ground back and then make the forks straight showing the axle leading and trailing and see what you come up with.
    The diagram you show has the axle ahead of the fork center line in all 4 pics. If the axle is trailing it will be behind the center line.
    www.CreativeCandy.org
  2. #12
    Senior Member Teazer's Avatar
    Mar 2010
    , IL, .
    That diagram is spot on. Imagine teh fork legs are like a motorcycle and you will see it doesn't change. Reduced offset => more trail. Add offset => Less trail.
    Just jack the rear end up to reduce trail and rake together. Get rake down to around 24 degrees and you probably need reduced offset to get enough trail. :-)
  3. #13
    The fork offset on a bicycle is done by curving the fork, on a motorbike it's done by putting the stem behind the line of the forks or using a leading axle. Same outcome.
    Senior Member hahnda's Avatar
    Dec 2006
    Cameron, WI, USA.
    http://www.scramblercycle.com
  6. #15
    Sep 2012
    I see where that makes sense now. I was mistaking trail for wheel base. The diagram before this reply shows that if you had a leading axle the trail in the pic would be cut in half or more and if the legs were reversed it would almost double trail. With some trees having very little offset and a leading axle fork you could conceivably have 0 trail. Would that be a bad thing?
  7. #16
    Nov 2008
    We went though this few years ago when people wanted to put modern or USD forks on 70's bikes.
    Trail increases in just about every case as the offset is less.
    Mostly it's 'A GOOD THING'
    No one complained about squirrely handling, they commented on how much more stable bike was at speed (lot of 'racing' CB350's)
    BTW, it's called trail because tyre contact patch trails the steering head line
  8. #17
    Sep 2012
    Can someone explain to me how the rake and trail effect handling. I notice the XR750 has much less rake than my bike. I have ridden choppers with a large amount of rake and stretch and realize they completely suck for handling.
  9. #18
    ok so looking at hahnda's diagram, how does moving the axle rearward and further up (like on a leading axle fork) reduce trail?
  10. #19
    Sep 2012
    I f you turn the fork backwards the axle will now be behind and lower, not further up. This would widen the line between the where the neck angle hits the ground and where the center line of the axle hits the ground. It wouldn't reduce trail but lengthen it.
  11. #20
    trail affects the straight line stability of the bike at the sacrifice of the wheel's ability to change direction. rake affects the wheel's ability to change direction at the sacrifice of a bike's straight line stability. The secret to good handling is finding the balance between rake and trail - which differs from bike to bike based on the chassis and suspension components. typically the more rake you have the more trail you have as well (although not always the case) so most choppers are excellent in a straight line but reluctant to change direction. Add in a skinny front tire and the fact that the longer the forks are the more weight is being distributed across them and not making it to the tire and you have an ill handling bike.
    or did you want something more sceintific?
  1. any photoshop experts?
    By ukTony in forum General
    Last Post: 01-10-2012, 02:15 PM
  2. CB 750 Engine Experts
    By mut in forum General
    Last Post: 05-20-2011, 03:12 AM
  3. Plunger Frame Suspension
    By JackC in forum Technical
    Last Post: 03-22-2011, 12:53 AM
  4. any Pie experts in tha house?
    By HackAsaw in forum General
    Last Post: 11-19-2009, 08:35 AM
  5. Electrical experts
    By mut in forum Technical
    Last Post: 01-23-2008, 07:01 PM
cafe racer caster
leading link fork cafe racer
plunger frame cafe rcer
