stainless braided brake hoses - Page 5
This is a discussion on stainless braided brake hoses within the Member Products forums, part of the Classifieds category; I just saw this ad and was wondering if "He makes custom lines like I need yet" and than saw you reference to me. I ...
Page 5 of 5 FirstFirst ... 345
Results 41 to 47 of 47
  1. #41
    Senior Member o1marc's Avatar
    Sep 2012
    Dawsonville, Georgia, USA.
    I need a setup pictured below but as one piece. I will put my own removable fitting on the open end because it has to thread through the center hole of the top triple tree nut before ending at the m/c. Can you do them in color or just the black pictured? I would like them blue if possible.
    www.CreativeCandy.org
  2. #42
    How complicated is that set-up? Why dont you just run 2 single lines straight from the MC to each caliper? Or a single line to one caliper, then a loop over the guard to the other caliper?. Would probably be cheaper without all those connector fittings, too.
  3. #43
    Senior Member pampadori's Avatar
    May 2007
    Richmond, Va., USA.
    Yeah, that is a bit complicated and looks pretty gross too. Why don't you call me at 804-505-0006. I'm not sure what bike this is even for but if its for a sportster and you are using the factory trees, I have something that bolts on for a splitter. If something else, we can run two hoses or one jumper like Hillsy mentioned. I can also get some unions like this:
    Name:  banjo union.jpg
    Or you could use any number of oe splitters like this CB750F splitter that holds two 10mm banjos on one side and one on the other. Lots of better options i think. I can do blue hoses as well.
    http://www.slingshotcycles.com
    Stainless braided brake lines and other odds and ends.
    Enter coupon code "caferacer" during checkout for 15% off
    The rule of thumb with brake lines (and hydraulics in general) is to keep it as simple as possible with the least amount of joins that you can. Connectors / splitters / joins can trap air bubbles and bleeding the system can then become a nightmare. Not to mention the increased chance of leaks with a bunch of joins like that.
  6. #45
    Senior Member bfont52's Avatar
    Dec 2012
    New Orleans, LA, .
    Is Pampadori still around? I emailed him about custom lines through his site last week and haven't heard anything from him. You out there Pamp? I need some lines!
  7. #46
    May 2007
    Richmond, Va., USA.
    Quote Originally Posted by bfont52 View Post
    I'm not sure what the subject of your email was, but I'm pretty well caught up on emails. What did you need?
  8. #47
    Dec 2012
    New Orleans, LA, .
    need some custom length brake hoses to fit my cb550 w/ cb1100f fork and swingarm. pm your email and i can send you specs. email woulda been from brady@bradyfontenot.com
  1. Modern old brake hoses
    By Greasyspoon in forum Technical
    Last Post: 05-15-2012, 05:32 PM
  2. Rubber brake hoses spongy?
    By MattM in forum Technical
    Last Post: 04-02-2012, 11:32 PM
  3. KZ900 brake hoses - who's got some?
    By pampadori in forum General
    Last Post: 02-05-2010, 07:48 PM
  4. stainless braided brake lines
    Last Post: 12-14-2007, 10:06 AM
  5. Braided SS brake lines?
    By ROSKO in forum Technical
    Last Post: 08-08-2006, 07:04 PM
cafe racer brake line
cafe racer brake line adapter
cafe racer brake line connector
cafe racer steel braided brake
cb750f braided brake lines
mcquean stainless hoses
stainless braided jumper hose
