oil in frame norvin
oil in frame norvin
This is a discussion on oil in frame norvin within the Project Builds forums, part of the Caferacer.net Forums category; our oil in frame vincent frame is finally finished. usually we would drop the engine slightly more than we have here. but that means that ...
Results 1 to 7 of 7
    Member dracken1's Avatar
    Mar 2009
    , , United Kingdom.
    oil in frame norvin
    our oil in frame vincent frame is finally finished. usually we would drop the engine slightly more than we have here. but that means that the engine oil drain plug has to be moved, it just entails drilling a tapping a 1/4" hole underneath the engine but this customer wanted to retain the standard drain plug. on the left side of the engine.
    plus we only fitted a head steady on the front pot, as there have been some concerns concerning expansion of the engine.
    www.the-norley.com
    Senior Member Saml01's Avatar
    Aug 2009
    Brooklyn, NY, USA.
    Thats unbelievable. Also a gorgeous engine
    1974 Honda CB360
    Senior Member Gambler's Avatar
    Oct 2009
    Bellevue, NE, USA.
    ....jaw drop......more please......
    \"I came to kick ass and chew bubble gum...and Im all outta gum.\"
    73 CL350
    Jul 2006
    New Castle, PA, USA.
    so what's the theory with oil-in-frame? doesn't the frame get hot as hell? welding slag in the oil? I don't know anything about it, just curious.
    very awesome.
    "This site is bullshit."
    Mar 2006
    south Orange County, CA, USA.
    Very pretty brazing, draken.
    About the drain plug, why not build an access hole right in the frame tube? The access hole could be a piece of frame tubing turned 90 degrees and brazed in, something like this: ==O==
    It could be reinforced all around, and it could have a removable cover built into it.
    I guess that idea wouldn't work if the oil is going to go in that part of the frame.
    Mar 2009
    , , United Kingdom.
    bronze welding requires very tight tolerances at the joints, it's only a form of golden coloured glue to simplify it. we purge the frame, from different directions, t45 is a very pure steel. and you can see that there is a bsa type filter in the frame, behind the engine but pointing towards it. different sized holes are drilled to ensure the oil flows the way you want it to. yes the frame gets warm, but it's what the customer wanted,
    the drain plug issue was to do with the engine not the frame, they wanted to retain the original, which meant we had to raise the engine slightly.
    the other problem with putting a vinny in a ready built wideline is the front exhaust pipe to frame down tube clearance. but as we build these frames that was taken care of at the begining.
    this link is not a brit bike, but a frame and rear suspension set up we made to take a 145 bhp aprillia motor.
    www.the-norley.com
    Aug 2006
    Portland, Oregon, USA.
    Wow....that's going to be something!
    ~Albert Einstein
  1. WTB: frame
    By Mikewars85 in forum Wanted
    Last Post: 12-18-2012, 02:29 PM
  2. norvin oil in frame for sale.
    By dracken1 in forum Parts For Sale
    Last Post: 03-15-2010, 02:09 PM
  3. NorVin at speed
    By ROSKO in forum General
    Last Post: 08-04-2008, 10:03 AM
  4. NorVin for sale, yes really.
    By ROSKO in forum Bikes For Sale
    Last Post: 02-09-2008, 11:58 PM
  5. New Frame
    By Camelhairy in forum Vintage Motorcycle Racing
    Last Post: 01-30-2007, 10:34 AM
norvin
norvin cafe racer
norvin cafe racer for sale
norvin engine for sale
norvin for sale
norvin frames
norvin motorcycle
norvin motorcycles
washington norvin for sale
