CB900 Cafe Racer project - Page 2
This is a discussion on CB900 Cafe Racer project within the Project Builds forums, part of the Caferacer.net Forums category; Originally Posted by tjurek51 ... i've seen lots of places offering Honda Racing transmissions... For cars or motorcycles? "Racing transmission" usually refers to the gear ...
Page 2 of 29 FirstFirst 123412 ... LastLast
Results 11 to 20 of 288
Like Tree90Likes
Thread: CB900 Cafe Racer project
  1. #11
    Quote Originally Posted by tjurek51 View Post
    "Racing transmission" usually refers to the gear ratios inside the transmission. Close ratio gearboxes are usually considered racing transmissions and Wide ratio gearboxes are what you find in street bikes.
    Almost guarantee your bike has wide ratio gear ranges and you would never be able to alter the transmission internal gears on that bike, which outputs to its secondary transfer case via a gear and not a chain.
    If you do what you plan to do, it will definitely be your own invention. You may as well remove the engine and put just that in a scratch built chassis, there is virtually nothing about the original parts that would be worth retaining. imho
  2. #12
    hmmm. according to specs, it is longer to accommodate the larger transmission box. you're saying this is not true? the other difference in the frame was the seat are subframe is supposedly lower as well. one quick question; instead of hunting and pecking for documentation, do you have any recommendations on where to find a better source of documentation for these bikes?
    No what I am saying is that the logic jump from having a little more room in the cradle to having an overall longer from is both flawed and ignorant. While it may be technically true the bottom of the cradle is extended to accommodate the transmission that doesn't make the backbone any longer. I'm pretty sure the f model super sports have a longer overall frame because the part of the frame that supports the rear passenger goes all the way to the taillight whereas on the C model it stops just aft of the shocks to mount the fender.
  3. #13
    I have never heard of anybody even trying to convert a 900/1000C to chain drive, because there is no reason due to the availability ofthe 900 and 1100 F. People have converted the Yamaha XS series because there no chain drive equivalent. The only reasonable way for you to do a conversion is to put an entire F engine in your C frame. Then you could put a longer swing arm in and move it forward closer to the rear of the engine in order to shorten the distance between the swingarm pivot and the countershaft sprocket. This would make it your own, since you would need to build the swingarm pivot area of the frame and work out the rear suspension. You could also look at putting your 900 top end on a trashed 750 so you could have a different combination of parts and get an engine cheap.
    WERA 119
    CCS 119
    CRA 119
    AHRMA not anymore
    Evan Esar
    I just took a look through google images for 900c's and there are no, none, zero, zilch, as in not any pics of nicely done performance cruisers on the first page, at all. There are a couple of weak attempts that look like they got started and gave up, there are a couple that tried to do bobber, chopper, brat style kind of things. There are not any that appear to have given comprehensive thought to the characteristics of the bike and play to the strengths and minimize the inherent deficits. Clearly this is a wide open field.
    Go for it!!!
    WERA 119
    CCS 119
    CRA 119
    AHRMA not anymore
    Evan Esar
  6. #15
    Senior Member Joep7's Avatar
    Sep 2011
    West MI, USA.
    Bike will never be ridden again once you go down to frame...calling it right now.
  7. #16
    Member tjurek51's Avatar
    Sep 2015
    Project is progressing slowly due to the need to research and, well, stare at the bike for awhile. sometimes, a new vantage point works so i had my bro-in-law build me a rolling work bench. see pic.Name:  Bike_on_bench.JPG
    first off, i thought i could salvage the rear wheel, until, that is, i noticed it's 3" smaller in diameter than the front. so, need to get a new wheel. not a big deal as there are a ton out there. Second, needed to decide on cafe seat style. most likely going with a fiberglass "Thruxton" style seat. still need a line on good options for the cushion, so if you have suggestions... third, need to paint the engine. any thoughts on a good paint that will last a long time? also, converting the shaft to chain is really not all that tough. Remove the secondary transmission and it's the same engine, gear box, clutch etc. as the other CB750/900's. but, i'll save the details for future posts. finally, i'm thinking of replacing the standard 5 speed gear box with a racing, close ratio 5 or 6 speed gear box. the only one i find online is from Nova Racing. anyone know of a place that sells rebuilt gearing?
    hey, i know most of you like to light up the poster with all sorts of negatives. bring it on. only motivates me more (which i appreciate). just please understand, i'm doing this for the fun of it. and to learn. just don't make it personal. i appreciate it.
    CBSam likes this.
  8. #17
    Jan 2008
    Southern Finland
    nice bench.
    close ratio gearbox and chain conversion for a C-model? Seat being the second most urgent decision after the new 17" rear rim (which needed a swap ANYWAY if doing a chain conversion).
    I am baffled.
    Also understand that the "negatives" might not be food for resilience by the pessimists - BUT actually words of wisdom. Don't ignore helpful advise just because you don't like hearing it.
    jcw likes this.
  9. #18
    Jul 2015
    Ontario Canada
    That bike weighs 611 pounds Dry, for gods sake don't get it wet!
    I'd say, if you want a light-weight CB900c, jack up the stickers and slide a new bike under it.[/I]
    That sir is hilarious, beer out my nose funny. cheers
    pwalo likes this.
  10. #19
    Jan 2008
    Southern Finland
    btw
Size:  90.6 KBName:  E14461A16.gif
    they don't look identical. At minimum the counter axle is different. The pictures of spare cases are so bad I cannot tell the differences there (besides the mounts)
  11. #20
    Sep 2015
    the clymer's book indicates the counter axle is different, which is expected, but only on the one side. the primary gearing is roughly the same. again, based on the book. find out when i get in there. appreciate the feedback. would like recommendations on engine paint if you have any. thanks.
  1. CB900 Cafe Racer project
    By tjurek51 in forum Project Builds
    Last Post: 09-19-2015, 12:09 PM
  2. My first cafe racer project! Help me
    By Riggs119 in forum Project Builds
    Last Post: 03-06-2013, 05:13 AM
  3. first cafe racer project
    By German.poopie in forum Project Builds
    Last Post: 02-23-2013, 04:43 PM
  4. cafe racer project
    By mirancorrecaminos in forum Technical
    Last Post: 10-20-2009, 09:18 AM
  5. This is my first Cafe Racer project!!
    By Capitol A in forum Technical
    Last Post: 05-18-2007, 07:52 AM
cb900c specs
google images of honda cb750 k7 engine mounts
