Honda 650 single build - Page 10
This is a discussion on Honda 650 single build within the Project Builds forums, part of the Caferacer.net Forums category; Past half way with the frame now..... Though a bit undecided about the front part.... currently just a couple of pieces of scrap tube to ...
Page 10 of 11 FirstFirst ... 891011 LastLast
Results 91 to 100 of 101
Like Tree53Likes
Thread: Honda 650 single build
  1. #91
    Senior Member unclerob's Avatar
    Jun 2015
    Kent, UK
    Though a bit undecided about the front part.... currently just a couple of pieces of scrap tube to hold everything in place.... it has to fit between pipes, leave enough space to get the motor out and be strong enough to do its job....
  2. #92
    Sep 2009
    Kansas City
    Quote Originally Posted by CaTacL1sm View Post
    I'd be so paranoid about an explosion
    If you use liquid water instead of air or vapor, there is little chance of danger, since water doesn't really compress.
  3. #93
    Sep 2009
    Kansas City
    I found a Eurospares article on hydroforming that was my first introduction to it years ago and (like everything on his site) is extremely coherent and detailed.
    http://www.eurospares.com/frame8.htm
    Feb 2009
    Fort Knox, Kentucky
    Quote Originally Posted by Tanshanomi View Post
    Euro Spares - FRAME ARTICLE #8
    Thanks!
    I thought that a cafe racer was a custom that you could do whatever you wanted and there is no right or wrong.
  6. #95
    Quote Originally Posted by unclerob View Post
    What about a bolt on cradle?
  7. #96
    Jun 2015
    Kent, UK
    yes, thats the way I went in the end....bit of a struggle though and about halfway through I noticed a couple of bosses above the ports that I'm fairly sure I could have drilled and tapped....and made life a lot easier!!
    Still, thats all forgotten now because I just discovered this on ebay....!!!!
    KEIHIN FCR Carburetor HONDA CB-1 | eBay
  8. #97
    Jun 2015
    Kent, UK
    Frame almost done now.....
    Plan is for a rear swingarm and drum off something like a CB550 at the back and Mk.1 Bandit forks at the front with this brake if i can afford it....or a single disc if not...
  9. #98
    Jun 2015
    Kent, UK
    Back to the single now.....finished a new design frame and just got tyres put on shiny new wheels....!
    drgonzo, Cyorg and thechief86 like this.
  10. #99
    Senior Member gs1327's Avatar
    Apr 2009
    Cleveland, Ohio, USA.
    You're kinda making the rest of us feel bad.
  11. #100
    Senior Member Cyorg's Avatar
    May 2014
    B.C.
    You made a wise choice for a single cylinder engine to hang in there, but a 600 cc Comet engine would be a good choice for your next one. Maybe knock off a couple of banks and then you can buy that drum brake too. Terry Prince in Aus will fix you up with all the gear to get 600 cc and some HP to go with it.
    "Non urinat in ventum"
  1. FAQ: Honda single piston brakes
    By JD in forum Technical FAQ's
    Last Post: 12-08-2011, 06:04 AM
  2. Ducati 250 single build thread
    By tonupoakland in forum Project Builds
    Last Post: 05-07-2010, 11:30 AM
  3. Biggest Honda single??
    By bryanderr in forum General
    Last Post: 07-16-2008, 01:04 PM
  4. FAQ: Honda single piston brakes
    Last Post: 06-11-2007, 05:14 PM
  5. basic performance parts for honda single...
    By jaguar in forum Vintage Motorcycle Racing
    Last Post: 11-16-2006, 10:48 PM
