Honda 650 single build
This is a discussion on Honda 650 single build within the Project Builds forums, part of the Caferacer.net Forums category; I've been thinking about this build for quite a while now, collecting bits for it and making sketches etc and finally decided to make a ...
Page 1 of 12 12311 ... LastLast
Results 1 to 10 of 117
Like Tree57Likes
Thread: Honda 650 single build
    Senior Member unclerob's Avatar
    Jun 2015
    Kent, UK
    I've been thinking about this build for quite a while now, collecting bits for it and making sketches etc and finally decided to make a start....
    Basic idea is something along the lines of a 60's clubmans race bike but built using fairly modern parts...so single cylinder, spoked 18" or 19" wheels, twinshock, full or maybe half fairing, single disc front and rear, no lights but road legal and as light as I can manage to make it. Hopefully looking something like this.....
    I picked on the Honda RFVC motor for no better reason than that I already had one spare and my father once owned a Rudge Ulster! Will also be using its headstock, yokes and hubs.
    Forks will be Suzuki 250 Bandit and the disc is from an Africa twin (I think) Brembo calipers and Ducati controls....all bits lying about on shelves that need using!
    Name:  003 (800x600) (4).jpg
    I've ridden them in the past and although ok ish I got the impression the engine was a bit mild so hoping to find a few extra horses in there later on.....no experience at all as far as that goes and any suggestions welcome please! Its not my main priority yet though and so far all I've done is pick up a 40mm FCR for it and made a start on a larger bore exhaust.
    I've decided to make the frame, something along the lines of a mk.3 Seeley, something I haven't done in a good while....though I do still make race/sports car chassis now and then so don't have any real worries about either making it straight or strong enough.
    So far, I've made a jig....which I know looks a bit of a lash but it is dimensionally accurate....24.5 degreee head angle, 56.5" wheelbase, and I'm making the various sections on plate glass so I can see if any distortion is happening and avoid building it in...
    For now I'm just using ordinary mild steel ERW tube, 11/4" with a 2mm wall but do have some T45 seamless same diameter and will decide whether to use it for a second frame later....fairly certain i won't get everything right first time and don't want to waste it!!!
    Jul 2015
    Ontario Canada
    Hey wait, what about the Cagiva. I'm sittin here waiting for the next picture and your off building a Honda. Whats up with that?
    Nov 2014
    Melbourne, Australia
    Talking
    yeah. how dare you start another before finishing something else.
    fucking over achiever.
    Jun 2015
    Kent, UK
    Sorry about that! Only major work left to do on the Cagiva is finish painting it, was freezing cold here in the UK last week so thought I'd leave it for a bit to warm up.....and now its baking hot! And as far as painting goes....any excuse not to do it works for me!
    This is way more fun ....todays work....most of the frame tubes in place....
    Can't quite decide whether to add just one more from the top of the headstock back centrally to the middle of the frame....any thoughts welcome please....
    Thats not the damper I'll be using, its just there to line things up....wheel is within an inch of full bump there btw. The top mount looks a bit chunky I know but wanted the frame narrow there and it'll be covered by the seat moulding eventually....
    Nov 2014
    it looks to me like they have a big bend point where the two tubes meet. i'd definitely brace that out.
    Jun 2015
    Kent, UK
    Thanks, yes, just needed a bit of encouragement to add another tube or 2, with luck it'll end up only weighing 20lbs or so more than the original bike!
    Anyhow, it came out of the'jig' today and ended up surprisingly straight....though finish welding yet to do and the area around the swingarm....plenty of opportunity to get it wrong yet...sitting low at the back but fairly happy with it so far.
    jaguar, drgonzo and TrialsRider like this.
    Jun 2015
    Kent, UK
    Wanted to sort the bars before I got onto the footrests/controls so picked a pair from a CBR for £5 from local breaker....a bit tired and bent but all he had in 41mm....
    But they cleaned up ok and replaced the bar section with a nice chromey one....
    Pic also shows fairly major design error....wheel/exhaust interface problem! Was trying to get the engine well forward and obviously tried too hard....not too concerned though as half way through making the exhaust I decided I didn't like it so glad of an excuse to have another go!
    Decided on a full fairing for it as well....seems to be quite a good fit....though I often think that and then spend a week altering it....I'll mould one tomorrow and try it up properly....
    TrialsRider likes this.
    Senior Member nic579's Avatar
    May 2010
    I like it, I have a thing for the big thumpers.
    I lusted after this one for years: Believe that this was built in Australia.
    CAPTAIN AWESOME likes this.
    Jun 2015
    Kent, UK
    Thats interesting....tuning info on these motors is a bit thin on the ground in the UK....thinking that the amount of trouble he's gone to with the oil system is for a good reason!
    Got the fairing made today but still in the mould and halfway done with the tank....making it from 20g steel as whenever I try to make an ali one I cock it up....
    I'm curious what you are using to weld or braze the frame tubing is that something you can share or is it a proprietary process?
  1. FAQ: Honda single piston brakes
    By JD in forum Technical FAQ's
    Last Post: 12-08-2011, 06:04 AM
  2. Ducati 250 single build thread
    By tonupoakland in forum Project Builds
    Last Post: 05-07-2010, 11:30 AM
  3. Biggest Honda single??
    By bryanderr in forum General
    Last Post: 07-16-2008, 01:04 PM
  4. FAQ: Honda single piston brakes
    Last Post: 06-11-2007, 05:14 PM
  5. basic performance parts for honda single...
    By jaguar in forum Vintage Motorcycle Racing
    Last Post: 11-16-2006, 10:48 PM
