Suzuki Intruder VS 1400 - Page 7
This is a discussion on Suzuki Intruder VS 1400 within the Project Builds forums, part of the Caferacer.net Forums category; Originally Posted by o1marc I had the same issue mounting Tokico calipers to mine. I was fortunate in that the lower legs on a triumph ...
Page 7 of 7 FirstFirst ... 567
Results 61 to 70 of 70
Like Tree16Likes
Thread: Suzuki Intruder VS 1400
  1. #61
    Senior Member MarkHarold's Avatar
    Jul 2016
    Sassafras, Victoria, Australia.
    I had the same issue mounting Tokico calipers to mine. I was fortunate in that the lower legs on a triumph are steel so it only required a single bracket made and welded on. In your case just put the caliper on the rotor where you want it and pressurize it to hold it in place while you use a piece of card board to mark your 4 hole locations. It's a piece of cake from there making a bracket and spacers.
    My calipers are Tokicos that I shaved the name off and put the Triumph logo on them. I was going to use the same 6 pot caliper you have, but they are too wide on the backside and would have hit the spokes.
    Thats a neat setup you've got there Marc, I'm not brave enough to think about welding a bracket to the fork. Replacing the Tokico name with Triumph is taking attention to detail to an unknown level to me, so top marks!
    The bracket for the little Tokico will be neat enough, hopefully I can do something decent with the 6 potter.
    Cheers, Mark
    Struth! Stone the crows and starve the lizards.
  2. #62
    Jul 2016
    Those zip ties are never going to hold
    You're attaching a cast aluminum part to a cast aluminum part and aluminum is a lot easier to shape and work with, ... I'd go with aluminum. Stainless looks nice in raw form but unless you have to make the parts super thin I'm not sure what the motivation would be.
    I did end up making the bracket out of aluminium, the scrap man had no stainless but did have some 10mm and 5mm aluminium plate, and it is easy to work with, so thanks for the advice.
    Turning scrap into a work of art.
    The bracket consists of 3 parts, 10mm plates that bolt to the fork and caliper and a 5mm spacer between them. I decided to bolt them together with 3 10mm stainless bolts with nyloc nuts instead of welding, I was concerned welding would warp the plates. Hopefully the brackets will not get hot enough to melt the nyloc nuts. It all lines up and is as compact as I could make it.
    Now I'll make the bracket for the 6 piston caliper.
    TrialsRider likes this.
    Cheers, Mark
  3. #63
    Senior Member 8ball's Avatar
    Nov 2012
    East TN
    .... I was fortunate in that the lower legs on a triumph are steel .......
    That's probably the first, and ONLY time that statement has ever been issued!
    Stephen J likes this.
    My GS550 Build Thread
    Jul 2016
    I've got a feeling that the 6 piston caliper may be an over reach, but I'm happy with the fabrication. I've ordered a stainless braided line, I will wait and see how the existing master cylinder performs, I will surprised if it drives the 4 piston caliper, and amazed if it drives the 6 potter.
    Now I will get back to work on the exhaust.
    Cheers, Mark
  6. #65
    The pistons are smaller on the 6 piston caliper compared to the 4 piston so if the MC works on one it will work on the other.
  7. #66
    Jul 2016
    The original brake had deteriorated over time, it became very spongy, I think mainly due to flexing of the line, so I'm expecting the new stainless braided line will stiffen things up, it's most probably just as important as the upgraded disc and caliper. I'm interested in seeing the difference between the 4 and 6 piston calipers.
    Cheers, Mark
  8. #67
    Jul 2016
    So much for 6 piston caliper, when I split the caliper to clean it I found a severe scratch in a piston, so I took it back to the spare parts man. I've ended up with the very first caliper I tried, the wheel has turned full circle but I've gone nowhere. At least I can use the same mounting bracket, the pads don't line up as well, they could be moved out a couple of mm, but I think it will be OK.
    I'm a bit frustrated with my lack of progress with the exhaust, I can't find the right guy to do the bends. The guys with the big flash machinery want me to make them millionaires, I'm looking for someone with a manual bender. Being a pound stupid penny wise sort of guy, I can see myself buying a bender, there is a 1 5/8" die on eBay at the moment, but I want 1.75". Decisions! Decisions!
    Cheers, Mark
  9. #68
    Nov 2014
    Melbourne, Australia
    not sure if ken at megacycle can help.
    i have had some custom bends done by a place in qld called beaudesert. they seemed pretty cool about doing what i wanted from sketches. Welcome - Beaudesert ExhaustBeaudesert Exhaust | Leaders in quality 4WD mandrel bent exhaust systems. Designed to improve power and fuel economy. Specialists in supplying custom mandrel bends. Supplying Most 4×4 Toyota ? Landcruiser, Hilux, Prado, FJ
  10. #69
    Jul 2016
    Hi Brad, I want to find a guy around Melbourne if I can, and I quite like the idea of having my own bender. Something will turn up, I'll keep looking for another month. I've met some real nice blokes, as well as some others. The last bloke I talked to wanted $600 to set his machine up. Yeah, right mate.
    Cheers, Mark
  11. #70
    Jul 2016
    It feels good to make some actual progress, the welding on the tank is now complete, barring any leaks. Tomorrow I will rinse it out with phosphoric acid and if all OK, prepare it for painting. I've bought a can of etch primer and a tub of filler. I think I could have done a better job of slicing and dicing, especially around the front, but at least it's back in one piece. The filler will cover my sins. I'm having second thoughts about the second tank, but that's way in the future.
    I've more or less accepted that I will have to go to a professional mandrel bender for the exhaust. I did actually buy a tube bender, but when I went to pick it up I noticed that the die section was oval, not a semi circle as I expected, and the seller offered to cancel the sale, which was very good of him. He advised me that I have to go mandrel, so, so be it. But then I wonder how hard it would be to fit a mandrel, I think it's possible, but I still need a bend die with the semi circle section.
    Cheers, Mark
  1. Suzuki Intruder
    By steveo in forum General
    Last Post: 04-02-2015, 10:22 PM
  2. Suzuki T500 fenders, or any older suzuki tach
    By mitchberry in forum Wanted
    Last Post: 01-27-2010, 04:19 PM
  3. Suzuki TC 90, possible?
    By Tigertree in forum Project Builds
    Last Post: 09-19-2009, 01:22 AM
  4. 1969 Bultaco Matador - $1400 - san fran
    By Eurago in forum Bikes For Sale
    Last Post: 02-10-2009, 06:04 PM
  5. Yamaha Turbo 600 dragbike/Bonneville bike - $1400
    Last Post: 01-09-2009, 10:04 AM
suzuki intruder 1400 tank
suzuki intruder 1500 cafe racer
vs1400 pant with
