Lowering forks. BMW K75S cafe build. - Page 2
This is a discussion on Lowering forks. BMW K75S cafe build. within the Project Builds forums, part of the Caferacer.net Forums category; they're damper rod forks, they don't do low speed compression. you can put emulators in them, or even adapt some cartridges in. the sports valves ...
Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 36
Like Tree1Likes
Thread: Lowering forks. BMW K75S cafe build.
  1. #11
    Nov 2014
    Melbourne, Australia
    you can put emulators in them, or even adapt some cartridges in. the sports valves have both rebound and comp adj, but the prices scares a lot of the not so serious off.
    7" of travel is nuts. well sprung 4" should be fine.
  2. #12
    Junior Member Panchoplanet's Avatar
    Apr 2017
    Found this @ Dennis kirk site, a simple weekend upgrade that should improve ridability.
    https://www.denniskirk.com/progressi....prd/58967.sku
    Pp.
  3. #13
    Apr 2017
    Found leaky tube while rearranging clippons and headlight and removing accordion tubes.
    Ordering seals and springs and some other assorted parts, in the meantime will tackle exhaust and electrical.
    If anyone has any resources for simplifying wiring please let me know.
    TIA.
    Pp.
    Nov 2014
    Quote Originally Posted by Panchoplanet View Post
    Pp.
    they're more accurately a dual rate spring. to be truly progressive the gap between the various coils has to increase incrementally. the rate they give is 0.63 - 0.89 kg/mm, which is too soft to on the soft side. that's what the std "too soft" ducati monster and ss forks springs are, and the k75 will be heavier on the front.
    the main issue i have with "progressive" springs is that they generally start off being too soft and giving a heap of sag (unless you preload the shit out of them), then they get too hard at the end. especially if the oil height is a bad spec and gives a lot of air spring effect.
  6. #15
    Apr 2017
    Thanks Brad Black for the insight, now I know why so many go for Honda and Yamaha forks in order to improve on this design.
    In the meantime replacement forks aren't on the menu or budget so will have to do my best with what I have.
    One other thing I noticed is that there is no dust shield on the lower legs after removing gaiters ,was hoping to get rid of them, don't like that BMX look they give.
    Any input will be greatly appreciated.
    Pp.
  7. #16
    Go back and re-read Brad Black's posts. Shorten the travel an inch or 2, fit the progressive springs and use slightly heavier fork oil set to the correct level. Put in emulators if you want to spend the money.
    WERA 119
    CCS 119
    CRA 119
    AHRMA not anymore
    Evan Esar
  8. #17
    Nov 2014
    you can probably just cut the std springs. i do that quite a bit.
  9. #18
    Jun 2013
    A2 MI
    Which increases spring rate...
  10. #19
    Nov 2014
    Quote Originally Posted by Farmer_John View Post
    that's the point.
  11. #20
    Apr 2017
    that's the point.
    What about cutting down the new progressive springs, say a 1/2 inch.
    That may be what I'm looking for, just have to figure out what dust seals to order so I can delete the accordion gaiters.
    Pp.
  1. My Bmw k100rs cafe build
    By Bmvn custom in forum Project Builds
    Last Post: 07-04-2016, 04:55 PM
  2. BMW K75 cafe build by guys at outlawUK
    By SJM in forum Project Builds
    Last Post: 06-19-2016, 02:37 PM
  3. Lowering BMW k100 forks
    By Jon_d_h in forum Technical
    Last Post: 11-24-2015, 04:39 PM
  4. BMW R100 SS Avon Lynx Cafe Build
    By KGBCafe in forum Bikes For Sale
    Last Post: 06-06-2014, 11:56 AM
  5. I want to build a BMW Cafe Racer
    By Macker in forum General
    Last Post: 03-03-2014, 01:40 AM
