electronic ignition
electronic ignition
This is a discussion on electronic ignition within the Technical forums, part of the Caferacer.net Forums category; while i've been forced to delay my more physical projects waiting on a collarbone to heal, I picked up on a project I had going ...
Results 1 to 9 of 9
    Sep 2008
    Rochester, New York, USA.
    electronic ignition
    while i've been forced to delay my more physical projects waiting on a collarbone to heal, I picked up on a project I had going on a few years ago. My plan was to make an electronic ignition for these old bikes with a computer controlled advance curve and knock detection. I've put together the circuit and mcu, and have them working together with a basic linear advance, and I was about to start working towards a couple more ideas I wanted to include so I wanted some engine wrenchers opinions on them first.
    first: I was playing with having the spark plug fire twice at low (<1000) rpm, theory being it would help the bike start easier
    second: I am going to change the linear advance to a pseudo curve based on maybe 8-16 points
    third: I am thinking about including a vacuum pressure sensor to monitor the vacuum and use that as a third degree in the rpm/advance scale.
    fourth: I am planning on allowing the advance to continue beyond the stock 3000 rpm until knock is detected
    any inputs would be helpful, what I've got now is pretty much an electronic replacement of the stock points, but I know it can do quite a bit more
    , Decrepit and Decomposing, .
    Make the array completely mappable in all dimensions and from a pc
    Do not omit the ability to allow any array input to affect the curve either positive or negative
    Sometimes, some engines need vacuum retards.... for example
    Sep 2008
    would the double spark at idle/low rpm help the bike start better?
    Sep 2008
    I don't see how wasted spark would help the bike start easier when cold. A lot of cars have it for emissions purposes, not smooth running.
    without giving away the milk farm, what are you using for pickups? magnetic? hall effects?
    you know the dyna 2000 does everything you are talking about for 4 cylinder bikes, but outside of HD there is nothing. If you had a digital iggy for say a cb450 that might be something else.
    Sep 2008
    the idea was to build an ignition that could be reprogrammed really quickly, with no advance limit, and include inputs for vacuum and knock, to more or less try to eek every extra bit of power from these engines as possible. the system runs with one hall effect pickup and one magnet so far, everything else is software, and I think it should be easy to switch from a cb350 to 450, it's just a matter of telling the software that the offset between firing #1 and #2 is 180' instead of 90'
    Sep 2008
    Senior Member Teazer's Avatar
    Mar 2010
    , IL, .
    Sounds like an interesting project. I was looking for a battery powered system and the best system I found so far seems to be from ignitech www.ignitech.cz their unit works on twins and triples and 4's and is fully mappable but doesn't have secondary overlay maps for Pressure, temperature etc the way that an EFI type ECU would. MoTeC do some nice ECU's but the cost is a little rich for me.
    IIRC ignitech does include TPS input on some units and may have a couple of other inputs but I don't think they are table driven.
    Knock sensor sounds like a great idea. Which sensor are you using?
    IIRC Honda found that after a certain point, flame propagation speed rises proportionately to rpm. That means that it doesn't need more advance at higher speeds.
    I haven't tested a CB350 on a dyno to map ignition timing to load, but i suspect that it may not want any more advance.
  1. electronic ignition? cb350
    By tshaw151 in forum Technical
    Last Post: 05-29-2010, 06:04 PM
  2. Electronic ignition
    Last Post: 07-04-2009, 01:30 AM
  3. XS 400 electronic ignition.
    By ssgtmass in forum Technical
    Last Post: 03-18-2009, 08:18 AM
  4. cb 750 electronic ignition
    By cbr900turbo in forum Parts For Sale
    Last Post: 09-02-2007, 03:36 PM
  5. electronic ignition?
    By teighlor in forum Technical
    Last Post: 12-28-2006, 06:30 PM
digital iggy ignition
