Attaching upholstery to seat pan
This is a discussion on Attaching upholstery to seat pan within the Technical forums, part of the Caferacer.net Forums category; I'm in the process. Got the pan almost finished. Steel. Sits on rubber bumpers on the frame rails, has two small bolts holding it down ...
Results 1 to 5 of 5
    Sep 2008
    , , Mongolia.
    I'm in the process. Got the pan almost finished. Steel. Sits on rubber bumpers on the frame rails, has two small bolts holding it down in the front, and will have some velcro sitched into the seam in a few places to wrap the frame rail and assist in holding the seat in place.
    I have used the original foam from the stock seat, cut down roughly already, which I will glue directly to the steel pan and finally trim down to exact size.
    I have a bunch of scrap black leather in pieces big enough to make a seat cover, and experience sewing.
    Where I get fuzzy is how to hold the leather cover in place. I have considered:
    1. aluminum or stainless pop rivets,
    2. the little plastic push-through car panel jobbers,
    3. similar steel push-through things used to hold the stock vinyl in place, or
    4. just glueing it. I used gorilla glue to reattach part of a seat cover before.
    The stock pan used the push-through doohickies mentioned above and 'teeth' cut out of the pan itself. I don't want to cut dozens of these teeth by hand. I'm also not crazy about having metal show on the outside edge of the seat cover...which includes riveting.
    Help.
    Senior Member Teazer's Avatar
    Mar 2010
    , IL, .
    The seats I had professionally covered were glued onto the base. That was the case on steel, aluminum and F/Glass bases,so that's what I would use.
    Senior Member CurbTiger's Avatar
    Apr 2009
    Portland, Oregon, .
    Glue it with quality contact cement. Plus you catch a buzz!
    None of that spray shit. Needs to be the brush on, stinky type.
    Two coats on the material side. First is meant as a primer.
    NE
    Subscribe to SIX HOT ISSUES!! of WarmPipe for only $29.99!!! Interweb NOW!!!!!
    Sep 2008
    , , Mongolia.
    Thanks guys. That sounds like a plan. And since you've been so helpful, I offer the gift of photos of my progress so far on a new seat for the XS650...
    This is a chopped up stock seat pan. Sort of a mock up/test run for the custom pan I'd be making:
    The university's maintenance recycling dumpster always has sheet metal in it. I made a cardboard cutout first, then went to work on this guy:
    Angle grinder and drill. I also used a file a little.
    Reused the rubber bumpers from the stock pan, and put two M8 screws in the front to hold it in place:
    The rear was wobbly, so I decided to add a few more bumpers, had to make a couple of small mounting brackets:
    It's looking good. I just need to strip the paint, glue the foam, trim the foam, make the cover, and glue that. Be done by morning. Not really.
    Sep 2008
    , , Mongolia.
    Finished: 1/3 to 1/2 the weight of the stock seat, almost as comfortable, and 10x more sexy.
  1. does anyone do upholstery?
    By TheGreg in forum General
    Last Post: 01-30-2012, 11:03 PM
  2. Attaching muffler to header.
    By OC Steve in forum Technical
    Last Post: 10-01-2011, 09:05 PM
  3. Project "New upholstery for me bump seat"
    By pampadori in forum Project Builds
    Last Post: 12-17-2009, 08:58 PM
  4. seat pan upholstery
    By dashor in forum Technical
    Last Post: 07-01-2009, 09:53 AM
  5. upholstery work and seats
    By joe c in forum Technical
    Last Post: 03-02-2007, 10:21 AM
attaching cafe seat to frame
attaching leather to aluminum
attaching leather to metal seat pan
cafe racer seat upholstery
gluing fabric to metal seat pan
how to attach leather to seat
how to upholster a cafe racer seat
how to upholster a seat pan
how to upholster metal seat pan
