81 CB650 Pilot jet question! Please help!
This is a discussion on 81 CB650 Pilot jet question! Please help! within the Technical forums, part of the Caferacer.net Forums category; so my bike only runs with the choke on, i took the carbs apart and with compressed air it doesnt seem to pass through the ...
Results 1 to 9 of 9
    Junior Member Lowlife_Louie's Avatar
    Mar 2013
    Unhappy 81 CB650 Pilot jet question! Please help!
    so my bike only runs with the choke on, i took the carbs apart and with compressed air it doesnt seem to pass through the pilot jets? it is like this on all the carbs. im kind of new at this so maybe im doing something wrong but air passes through the main jets freely, not the pilots. air should pass through these i believe. any ideas? they are pressed in so i cant remove to clean. any info helps. thank you!
    Senior Member gs1327's Avatar
    Apr 2009
    Cleveland, Ohio, USA.
    Seems like it would take large huevos to join a forum and immediately demand help. Maybe it's normal and I'm an old fart. Probably.
    Senior Member o1marc's Avatar
    Sep 2012
    Dawsonville, Georgia, USA.
    There was no demand. He merely asked for help. Takes no huevos at all to do anything on the internet. You're right, you must be old.
    I may be old, but I got to see all the really good bands.
    www.CreativeCandy.org
    Senior Member hahnda's Avatar
    Dec 2006
    Cameron, WI, USA.
    I think those pressed in jets are removable. Not easily but it can be done.
    http://www.scramblercycle.com
    Senior Member dirkchecken's Avatar
    Jan 2012
    there pressed in. some tap them than pull them out. you may get the thru passage unblocked (fine wire)but there are 6-8 "frothing" holes on the sides of the jets that you wont get unplugged. I went thru your pain. give up on the 81's right now before you spend more time or money. get a 82 set. they have screw in idle jets. the main jets are smaller 118 - 120. so take the 120's out of the 81 and put them in the 82,s. check ebay. you may find a set in the $100-150 range. clean them good. then clean them again .keep the stock airbox. if that's not on. put on a good quality air filters. no cheap pods. the 4-2 k and n's work good. theres a OHC Honda forum. also a 650 one too. very helpful. Honda : CB | eBay
    Mar 2013
    Quote Originally Posted by gs1327 View Post
    If you have no positive comments or helpful information don't bother posting. maybe im young but that's what a respectful old fart should do.
    Sep 2012
    Quote Originally Posted by Lowlife_Louie View Post
    Now there's heuvos.
    Member SeeBeeForeHunned's Avatar
    Apr 2013
    lol... awesome.
    Jan 2008
    Southern Finland
    read that again. To yourself.
    This ain't no helpdesk for dummies. Sure people help (and know a shit ton - as this thread alone has proven) but when you ask like the entitled bitch you are you can rest assured the the amount of help you will get will directly reflect your attitude.
    So tone it down a notch. Act like you were in a room with real people and it will work out much better.
  1. CB650/ 750 STATOR
    By kylebruce21787 in forum Technical
    Last Post: 05-17-2012, 01:36 AM
  2. ? on pilot jets
    By messeduptriple5soul in forum Technical
    Last Post: 01-05-2012, 04:06 PM
  3. 81 cb650 custom, on a 79 cb650 frame
    By ScrewyLouie in forum Project Builds
    Last Post: 01-31-2011, 09:12 PM
  4. CB400T Pilot Screw Adjustment
    By Cupid in forum Technical
    Last Post: 12-24-2009, 12:01 AM
  5. 1980 CB650?
    By Trefmawr in forum General
    Last Post: 03-10-2006, 01:44 AM
1980 cb650 only runs with choke
81 cb650 carb jets
81 cb650 pilot screw
81 cb650 pilot screw adjustment
cb650 carb idle jet
cb650 carb rejet
cb650 pilot jet
honda cb 650 jetting
youtube honda cb 650 pilot jet repl
