1978 Suzuki GS750
1978 Suzuki GS750
This is a discussion on 1978 Suzuki GS750 within the Technical forums, part of the Caferacer.net Forums category; So this is a second post about my bike that I just picked up. The first was in my original post when I mentioned it ...
Page 1 of 7 123 ... LastLast
Results 1 to 10 of 69
    Senior Member The Chief's Avatar
    Feb 2014
    Watertown, NY
    1978 Suzuki GS750
    So this is a second post about my bike that I just picked up. The first was in my original post when I mentioned it and it just kinda of took off from there with everyone trying to help me troubleshoot it. Im just moving it to this section so that its correctly posted.
    So I picked up this Suzuki GS 750 for 300 bucks. What you see is the way it came, I havent done anything yet to it. The seat in the pic is for a Ducati monster, that I had laying around from another build and I just through it on to see what it looked like. The bike didnt come with a seat. I snagged it up cause the tank and fender are in show room condition, no dents, dings or scratches. It wouldnt start and had no spark. I since have replaced the coils, plugs, and plug wires and now have spark. The bike still wont start, its trying but its just popping and chugging. So now im going to move to the carburetor tomorrow and clean it out completely. I fixed a couple vacuum leaks on it which gave it a little more encouragement to start but not enough. On the bottom of each of the carbs is a hose fitting, is anyone familiar with this particular carb? Should those be capped or left open?Name:  photo(5).jpg
    The fittings on the underside of the float bowls are overflows. From the factory they had hoses on them that ran down between the swingarm pivot and the gearbox.
    You don't need to plug them, but putting some hoses back on them would be a good idea.
    Feb 2014
    Watertown, NY
    Aaah Ok that makes sense! Thanks! My yamaha didnt have those so I was curious.
    Feb 2014
    Watertown, NY
    Ok I pulled the carbs and they look like they have recently been gone through. They were very clean. I did notice that it was re-jetted, so at some point someone was thinking when they put the air pods on. They put 105 Mains versus the stock 102s and they put in 17.5 slow versus the 15 stock slows. I really stumped...these carbs are very clean, no clogged jets or anything......Ideas??Name:  1.JPG
Size:  421.4 KBName:  11.JPG
Size:  391.4 KBName:  111.JPG
Size:  340.3 KBName:  photo 1.JPG
Size:  431.2 KBName:  photo 2.JPG
Size:  364.9 KBName:  photo 3.JPG
Size:  411.8 KBName:  photo 4.JPG
    Depends on your definition of clean - they look quite dirty to me. Look at all the slime that's on the floats.
    And the biggest problem is the areas you can't see - all the passages behind the jets easily fill with gunk and the bike will never run right.
    Carb cleaner and compressed air are your friends here - you also need to remove ALL the jets (including the idle jet - the one inside the float bowl gasket at the front of each carb. Be careful as it has a tiny spring, washer and o ring behind it). Pretty much everything brass comes out.
    But the brass tube that sticks out of the carb base doesn't come out - you need to make sure it is clear as well as the corresponding passage it goes into in the float bowl. A piece of wire off a wire brush pushed into the end of a matchstick makes a handy tool for these places.
    Senior Member nicebikemate's Avatar
    Oct 2013
    Oxford, England
    Lol, i'm a grotty bastard and I still wouldn't call those clean. Careful with the carb cleaner as it's pretty nasty stuff and while i'm not sure if it'll damage the floats or not, i wouldn't risk it.
    Also, this $20 thingy is great - a bit of vinegar and a few minutes…..
    Feb 2014
    Watertown, NY
    Im not getting any combustion at all. I can get a little bump if I give it a shot of starting fluid but it wasnt much. Im going to pull all brass like you said and clean them as I didnt do that yet. Whats that thing you have there?
    Oct 2013
    Oxford, England
    [QUOTE=The Chief;285492]Im not getting any combustion at all. I can get a little bump if I give it a shot of starting fluid but it wasnt much. Im going to pull all brass like you said and clean them as I didnt do that yet. Whats that thing you have there?[/Q
    Ultrasonic cleaner.
    Feb 2014
    Watertown, NY
    Hillsy,
    I just pulled all the jets and brass fittings. I tried that trick with the copper wire, that works really well. No clogged ports on anything, no corrosion or any discolored pieces. I can see light through all the ports on everything. Cleaned the grime off the floats with Sea Foam. Which direction should I go in now? Should I put stock jets in?
  1. Suzuki gs750 big bore kit/ 851
    By fffast in forum Parts For Sale
    Last Post: 07-08-2011, 08:53 AM
  2. '78 Suzuki GS750
    By Derby in forum Bikes For Sale
    Last Post: 05-02-2011, 02:28 PM
  3. Suzuki GS750 neo cafe (Can you say DIY?)
    By tombo in forum Project Builds
    Last Post: 01-25-2010, 07:54 PM
  4. 1978 gs750 - Queens, NY
    By Geeto67 in forum Bikes For Sale
    Last Post: 05-12-2008, 11:29 AM
  5. 1978 GS750
    By Pete Casper in forum Technical
    Last Post: 09-07-2007, 10:00 AM
1978 gs750 jets
1978 gs750 suzuki
1978 suzuki gs 750 won't start but has fire
1978 suzuki gs750 cafe racer
1978 suzuki gs750 mic carb dead spot
78 gs750 jetting
78 suzuki gs750 white smoke
gs750 manual carb sync
gs750 petcock positions
