flat slide dimensions
This is a discussion on flat slide dimensions within the General forums, part of the Caferacer.net Forums category; are flat slide carbs generally less long than a round slide? i have a kawasaki g5, and the round slide that is with it has ...
Results 1 to 5 of 5
    Dec 2007
    McAlester, Oklahoma, USA.
    i have a kawasaki g5, and the round slide that is with it has the throttle slide frozen in it.
    im trying to get it out. but i wouldn't mind switching to a Flat slide or something
    but because it fits between the covers it can't be physically larger, in fact if i rig it, it will likely need to be smaller.
    this probably should have been in technical sorry.
    Dec 2007
    nevermind, sudco carries one. clamp-mount vm18 if anyone has one of these or is a sudco distributor....
    Dec 2007
    Senior Member sdurand76's Avatar
    Jan 2009
    Montreal, Quebec, Canada.
    flat slide mikuni's are generally about half the thickness of a round slide....but the slides aren't interchangeable
    Jan 2009
  1. Flat slide, Smooth bore Carbs for 1988 FZ600
    By John Westcott in forum Wanted
    Last Post: 09-25-2012, 08:42 AM
  2. honda drums and dimensions.
    By engel in forum Technical
    Last Post: 11-02-2010, 09:17 PM
  3. Brass slide question
    By CurbTiger in forum Technical
    Last Post: 05-09-2009, 03:35 AM
  4. buying new slide diaphragm...
    By OctaneHauler in forum Technical
    Last Post: 03-03-2009, 06:03 AM
  5. Megaphone dimensions
    By panic in forum Technical
    Last Post: 11-26-2004, 03:48 PM
