CB900F electrical systems
This is a discussion on CB900F electrical systems within the General forums, part of the Caferacer.net Forums category; Normally pretty strong? Local bike is advertised cheap, but isn't charging. I know it could be a stator, regulator, battery, or just a loose connection. ...
Results 1 to 9 of 9
    Mar 2004
    Raymond, NH, USA.
    Normally pretty strong? Local bike is advertised cheap, but isn't charging. I know it could be a stator, regulator, battery, or just a loose connection. Anything on these bikes known to suck?
    Besides being heavy bikes from the 1980s....
    Senior Member raven's Avatar
    Jan 2009
    milledgeville, ga, USA.
    basically the RR can die and blow up the rotor or stator or vice versa. Poor connections in the system can kill all of it. Brushes are the simple fix...
    It takes a little to get em back going but they are certainly no worse (or no better) than alot of the other systems of the era. The only big advantage is everything is easy to get off
    Bike:
    Buell X1
    Honda S90 (box of parts)
    Honda CB750C (runs)
    I would bet on the regulator / rectifier. Check all the yellow wires for overheating evidence. They don't have brushes. They are a battery excited alternator. I have seen the rotor fail more often than the stator.
    WERA 119
    CCS 119
    CRA 119
    AHRMA not anymore
    Evan Esar
    the electrical system on all these early 1980s hondas are known to suck hard. The stators are known to fail as is the reg/rect and the pulse controllers. the fortunate thing is except for the stator the rest is pretty cheap. Most of the cbF guys update the 900f regs with cbr600 units.
    Jan 2009
    http://www.crc2onlinecatalog.com/stators.htm
    right below the rotor are listed brushes...Battery juice gets to the rotor to excite the alternator via these brushes (with all due respect ) That being said, it probably aint the issue....
    Bike:
    Buell X1
    Honda CB750C (runs)
    My goodness, I stand corrected, thanks. In all the years I worked on those things I don't think I ever had to replace a set of brushes, so I forgot about them.
    I agree, probably not the issue.
    WERA 119
    CCS 119
    CRA 119
    AHRMA not anymore
    Evan Esar
    WERA 119
    CCS 119
    CRA 119
    AHRMA not anymore
    Evan Esar
    Jan 2009
    The only set I have ever seen replaced (online) was due to mechanical failure, the brush actually broke probably due to a manufacturing defect.
    Interestingly enough on my bike, it charged to spec even after sitting for 25 years. I did end up replacing the connector shell going down to the engine as it had nearly disintegrated over time but so far no issues on this one. Probably fail next time I start it [xx(]
    Bike:
    Buell X1
    Honda CB750C (runs)
    Jan 2009
    Bike:
    Buell X1
    Honda CB750C (runs)
  1. Rick's Motorsport Charging Systems for CB350
    By davidw in forum Technical
    Last Post: 11-19-2010, 11:23 AM
  2. Tell me about aftermarket ignition systems
    By Saml01 in forum Technical
    Last Post: 09-29-2009, 09:04 AM
  3. electronic ignition systems
    By lovethosetwins in forum Technical
    Last Post: 02-06-2009, 03:57 PM
  4. NYC Council - exhaust systems.
    By Pete Casper in forum General
    Last Post: 12-14-2008, 05:47 PM
  5. 350 exhaust systems
    By JackC in forum Vintage Motorcycle Racing
    Last Post: 06-12-2007, 08:10 PM
cb900 electrical problems
cb900f alternator brushes problem
cb900f comon elctrical problems
cb900f electrics
cb900f rotor
cb900f stator problems
charging system problem cb900f
checking the rotor in cb 900f
ricks motorsports honda cb350 alt failure
