The best Fame Paint EVER!
This is a discussion on The best Fame Paint EVER! within the General forums, part of the Caferacer.net Forums category; http://www.eastwood.com/underhood-en...-gray-set.html Just needed to say that Eastwood Spray Gray is the best frame paint I've ever used. I shot the unprimed, scotchbrited frame of the ...
Results 1 to 7 of 7
    Senior Member trepanned23's Avatar
    May 2008
    EAST! Hollywood, 90004
    Just needed to say that Eastwood Spray Gray is the best frame paint I've ever used. I shot the unprimed, scotchbrited frame of the CS1 with this stuff over the weekend, last weekend. 3 coats. Its acrylic lacquer so you only wait about 6 or 7 minutes (in California) to shoot another coat. Get close, about 5 or 6 max inches away.
    A couple days later I needed to grind some off to braze my seat and tank brackets . . . . HOLY SHITE. . . . This stuff cured to a powdercoat type of finish. I had a drum sander, flapper deal on my drill and let me say that it took a lot of gas to get this paint off the frame and prep for welding. I am impressed.
    I might shoot a coat or two of SPRAYMAX 2K Clear Urethane over the frame if I have any left after the body work and tank job - just to really make her POP! This is good stuff.
    Senior Member parks61's Avatar
    Jan 2006
    i've used the eastwood chassis paint (black) for a couple frames now. it has a nice medium lustre finish but when i've gone to recoat (touch-ups etc.) the new paint makes the old paint go wrinkle
    didn't seem to matter whether the original surface was a week old or a year old....same result. guess i'll try their underhood-engine paint sometime.
    -parks
    I\'m not handsome
    Oct 2004
    thanks for the review. i have always swore by PJ1.
    cheers,
    Aug 2006
    Portland, Oregon, USA.
    I have loads of Eastwood stuff laying around, generally been pretty pleased.
    Good to hear the gray works.....
    ~Albert Einstein
    Senior Member champ's Avatar
    Apr 2007
    , New Hampshire, Monaco.
    Yep Eastwood. I've used the extreme chassis gloss black on the TA125, Bultaco and Motobi with excellent results-expensive. Some good stuff.
    I also use an industrial grade from work called Great Dane and have had excellent results as well-free. Were talking spray bombs here folks!!
    Johnnyracer
    Senior Member mudmonkey's Avatar
    Dec 2007
    oakland, california, .
    Oct 2004
    nathan,
    too funny....i thought the same thing, but i was too lazy to look for an img file.
    cheers,
  1. fame at last!
    By ukTony in forum General
    Last Post: 08-21-2010, 01:19 AM
  2. Paint Q
    By Dart7383 in forum Technical
    Last Post: 06-24-2008, 02:40 AM
  3. Brush with fame
    By craig641 in forum General
    Last Post: 05-09-2007, 06:55 PM
  4. Post your fame bracing pic's
    By RichieD in forum Vintage Motorcycle Racing
    Last Post: 10-03-2006, 02:02 PM
  5. Our 15 minutes of fame have come
    By imslow in forum General
    Last Post: 09-18-2003, 10:26 PM
