Velocity stacks
Velocity stacks
This is a discussion on Velocity stacks within the General forums, part of the Caferacer.net Forums category; Looking for velocity stacks for Cb350 stock carbs.Any suppliers out there. Keith,...
Results 1 to 10 of 12
Thread: Velocity stacks
    Senior Member keith99's Avatar
    Jun 2009
    chalfont, pa, USA.
    Velocity stacks
    Keith,
    Official Site Vendor ukTony's Avatar
    Jul 2009
    Bridlington, East Yorkshire, U.K
    this is where i get mine, they are in UK but will ship anywhere..
    we call them 'bellmouths here'
    http://www.custom-fasteners.co.uk/ac...ellmouths.html
    'old hooligan...
    The best performing stacks that I have found are the stock rubber ones from the stock air filters. I clamped green foam uni filters on mine. The jetting didn't need to be changed after I put the filters on the stacks so I figured they weren't very restrictive. The difference in the velocity stacks and bare carbs was changing the main jets from 100 to 130.
    WERA 119
    CCS 119
    CRA 119
    AHRMA not anymore
    Evan Esar
    Oct 2004
    i used malossi velocity stacks. we sold them at cosmo. larry charged me $20.00. those were the days my friend....walking up to his desk after work with a box full of stuff for "let's make a deal." the malossi stacks were just a little bigger ID then the intake OD of the CV carbs.....my original fix was to use asparagus purple rubber bands, but was changed mid season for a small section of bicycle inner tube stretched over the intake lip and friction fitment of the stacks. they never vibrated off or were knocked off over four seasons of racing.
    google malossi.
    p.s. - ah hell....here you go: http://www.malossistore.be/?gclid=CK...Fdx05QodUhRg0g
    or: http://www.malossistore.be/Prodotto....=M&C=05%200392
    or: http://www.malossiusa.com/
    ***** - please verify the intake OD and the stack ID before ordering! - *****
    Oct 2004
    keith,
    i haven't forgotten to call you. got busy, and also forgot that i'm going to the banquet on Saturday. clancypants and I will be cruising home on sunday. maybe I can convince him to come over with me and check it out then. i'll call you from the road.
    Senior Member oldhondacafe's Avatar
    Mar 2009
    Riverside, Ca., USA.
    I have a set, they are for cb350/cb450, I had them on my cb500tI'll try to find a pic. I have 2 pair and I'll sell one.
    http://i707.photobucket.com/albums/w...lsandgages.jpg
    they are 1 piece spun aluminum and they push on and stay on realy well, they have a fine brass screen on the bell end. $25. for the pair, new in the box, comes with a clamp that looks just like stock. Fits 49mm, made in japan by "toko", posibly NOS?
    \'78CB750f,\'76 cb500t,\'5-CB/CL450 basketcases,\'68 CL175,\'66 CA77/in a CL72 frame,\'1971 DT1f,1988cbr1000f,1987cbr1000f
    Jun 2009
    chalfont, pa, USA.
    Hey Don,
    So are you saying that the out side diameter of the velocity stack is 49mm?
    The inside diameter of my keihin carbs are 38mm and 50mm out side.I don't think theyll fit. If they will fit ill take them.
    Keith,
    Mar 2009
    They were listed (on e-bay) as fitting cb350 and cb450, I measured them (with a ruler) at 49mm ID It says cb450 on the box. I put my caliper on it and it easly goes to 50mm. I just saw some listed for $49. a pair. I bought 4 of them for that so I'll split it with you. Here's a pic.
    http://i707.photobucket.com/albums/w...1062010087.jpg
    Oct 2004
    weird as i just saw a pair of these sitting in the backseat of a saturn. apparently some lesbian is building an FCB bike.
    too funny!
    Jun 2009
    chalfont, pa, USA.
    Don ill take them. Just email your address and ill send a check right out.
    Thanks, Keith
    Tex, rough weekend!! Let me know when a good time to get together. Im itchen to get get her runnin. If it better for you i can always bring her to your place if that helps. Thanks
  1. 52mm Velocity stacks
    By mlinder in forum General
    Last Post: 03-19-2015, 07:37 PM
  2. Velocity Stacks
    By crashkillsvince in forum Technical
    Last Post: 12-15-2010, 04:29 PM
  3. Small Velocity stacks
    By Whitehurst in forum General
    Last Post: 01-04-2010, 10:01 PM
  4. Looking: Velocity Stacks?
    By gryffin in forum Wanted
    Last Post: 12-25-2009, 09:43 PM
  5. Velocity Stacks
    By ct77 in forum Technical
    Last Post: 10-21-2007, 05:16 PM
49 mm velocity stack filter
49mm velocity stacks
52mm velocity stacks
cafe racer velocity stacks
cb 450 cv velocity stacks
foam air filters to fit over velocity stacks
velocity stack 49mm
velocity stacks 49mm
