where can I get 15hp capable 2speed transmission - Page 2
This is a discussion on where can I get 15hp capable 2speed transmission within the General forums, part of the Caferacer.net Forums category; I didn't even think about it but yeah, if there is no current going through the motor it freewheels so you really wouldn't need a ...
Results 11 to 20 of 23
  1. #11
    I didn't even think about it but yeah, if there is no current going through the motor it freewheels so you really wouldn't need a clutch. However, how do you get that to work with regenerative braking where the motor goes from being a motor to an alternator as you slow down?
    Feb 2006
    quote:Originally posted by mlinder
    Again, torque and HP are different ways of expressing the same thing. HP at a given RPM is always the same torque, and vice-versa.
    Right, but gas v. electric they devolop their power much differently.
    On equipment that can be ran either/or the easy rule of thumb is double the electric hp for a gas engine. i.e. 10hp electric = 20hp gas
  3. #13
    , Decrepit and Decomposing, .
    It's done via the controller.
    I'd agree that at least 2:1 would be a good baseline although reasonably irrelevant.
    It's done via the controller and most common ev motors will actually generate dc when motored.
    Im not very experienced with the latest ac high zoot stuff and havent studied it due to apathy.
  6. #15
    Senior Member UncleErnie's Avatar
    Feb 2009
    Asheville, , .
    Get one from an old Schwinn bicycle?
    Don't scooters have this kind of tranny?
    (I have no idea)
    LOOK OUT IT\'S COMING THIS WAY!
  7. #16
    Nov 2008
    Your Moms House, USA
    That's like saying 10 gallons of water is the same as 20 gallons of paint thinner...
    Horsepower is horsepower. Please don't think I'm trying to come off as a dick, I'm not. But measurements are measurements. They don't change depending on what you are measuring. A cubic foot is a cubic foot, regardless of what's occupying that space.
    The issue that's run into with electric motors is that the torque curve over RPM is flat and available instantly, which is completely different than internal combustion engines, which can be hard on attached machinery.
  8. #17
    Aug 2006
    Portland, Oregon, USA.
    I think you hit on it Mark....
    It's perception. That10hp electric hits RIGHT NOW with all the torque it's got to offer.
    The gas engine has to spool up, so a transmission that's going to be run with an electric motor must be stronger than what a gas engine needs. At 0rpm and full mechanical load that electric motor can wreak some havok.
    ~Albert Einstein
  9. #18
    Wow..... now the next thing for practical applications that can be thorny
    would be bearing speeds
    As in very few motorcycle or even cvts are designed to handle 15k input shaft speeds regardless of the load
  10. #19
    Nov 2008
    Oh, good point. Hadn't even considered that far ahead yet.
  11. #20
    It can get even stickier when doing gear reduction gear boxes and on the over-run if the motor's bearings are already marginally engineered, if durability is a concern.
    EV applications are generally a bit easier when using a motor which operates with shaft speeds more similar to a diesel engine than a F1 engine even though there are ways to make most anything work.
  1. Most capable?
    By JPellegrino in forum General
    Last Post: 08-22-2011, 03:38 AM
  2. Kawasaki that is capable of time travel
    By oneworden in forum General
    Last Post: 05-29-2010, 12:42 AM
  3. CB350 transmission
    By Teazer in forum Project Builds
    Last Post: 04-04-2010, 08:05 PM
  4. transmission prob cl 350
    By baxter73 in forum Technical
    Last Post: 05-13-2005, 10:26 PM
  5. RS 125 transmission oil
    By aaron in forum Technical
    Last Post: 05-10-2005, 09:40 PM
