belt drives for Triumph motors
This is a discussion on belt drives for Triumph motors within the General forums, part of the Caferacer.net Forums category; Hello folks, I am in the process of installing a Tony Hayward belt drive primary on my '69 650 motor. When I go to tighten ...
Results 1 to 4 of 4
    Wes
    Wes is offline
    Wes's Avatar
    Oct 2002
    Hello folks,
    When I go to tighten everything down.. the clutch basket wont move/rotate any more. Something is seriously binding here...
    Has anyone here had any experiences with these belt drive kits?
    Looking for clues at this point....
    thanks in advance.
    Wes
    Senior Member aaron's Avatar
    Mar 2002
    Melrose, MA, USA.
    Wes,
    Welcome to the board. I have delt with this before I just have to remember what the resolution was. I think it was the copper thrust washer behind the rollers that we ended up using a thinner version of. I have to call my buddy Hutch and see as he would "What the fuck" we did to fix this.
    Aaron
    Wes
    Wes is offline
    Wes's Avatar
    Oct 2002
    Thanks for the reply Aarom.
    Yea.. my motor builder was pondering a thinner thurst washer. Also maybe machining a bit of the surface of the clutch basket down.
    This one Cat told me to check the size of each of those little roller bearings. He was saying that even if one of those was longer then the other... it could cause the binding.
    So... I do have some clues.... but wanted to check here to see if anybody else has encountered this.
    I really need to get this bike on the road.
    Wes
    Mar 2002
    Melrose, MA, USA.
    I believe we were suspect of the rollers as well and found nothing. Then ended up finding a slightly thinner thrust that we thought would help but in the end we machined down the surface of basket.
    Aaron - I think the rollers would only make it drag not freeze. I'm not sure.
  1. So she likes motors...
    By santa_ana in forum General
    Last Post: 01-23-2011, 10:58 AM
  2. Triumph Belt Drives
    By imslow in forum Technical
    Last Post: 11-12-2009, 08:23 AM
  3. Another notch on the belt
    By Pinche Chingadera in forum General
    Last Post: 03-09-2009, 02:11 AM
  4. Arcing Brake Shoes w/ Belt Sander - huh?
    By trepanned23 in forum Technical
    Last Post: 12-19-2008, 08:30 PM
  5. Amazing motors
    By jbranson in forum Technical
    Last Post: 03-15-2006, 05:03 PM
hayward belt drive kits
hayward belt drive kit?
installing belt drive on triumph
installing map belt drive on 650 triumph
tony hayward belt drive
tony hayward belt drive kits
triumph belt drive
triumph belt drive kit
triumph hayward belt drive
