Cb750 front end on a oif trumpet?
This is a discussion on Cb750 front end on a oif trumpet? within the General forums, part of the Caferacer.net Forums category; This used to be a back in the day semi common mod. Anybody know what is needed to do this swap?...
Page 1 of 7 123 ... LastLast
Results 1 to 10 of 69
    Oct 2004
    for starters.....a CB750 front end, a triumph frame, and a couple quarts of oil.
    Oct 2004
    i'll be here all week.
    try the roast beef.
    Well you gave me one of those things, and a scorching case of bike herpes.
    Oct 2004
    you had plenty of time to back out of the deal.
    and you had motorcycle STDs way before me.
    I am not complaining, just trying to valtrex the situation.
    , Decrepit and Decomposing, .
    Are you sure about that 'back in the day common' part?
    Have you seen it done using the cb trees?
    Senior Member cb650pk's Avatar
    Aug 2010
    Long Branch, New Jersey, USA.
    I have seen a couple over the years. maybe not as common as I think but I have seen more than one so that is common to me.
    Last one I saw was 2 years ago. I remember it uses the fork, wheels, whole brake setup but I can't remember the trees used. For all I know they could be custom trees.
    cb650pk: that looks like a GL1000 front end, at least the trees and the wheel are. The GL uses 37 or 38mm forks (I can't remember) but uses the same exact stem as the cb750 so however that happened would probably work for me. Got any more info?
    Aug 2010
    It is GL wheel and k8 front end.
  1. CB750 front end compatability...
    By tomz. in forum General
    Last Post: 09-13-2011, 05:56 PM
  2. CB750 Front end
    By 360Cafe in forum Technical
    Last Post: 09-13-2009, 12:50 AM
  3. CB750 Front end...
    By Rocan in forum Wanted
    Last Post: 04-29-2009, 03:09 AM
  4. 18" tire on front of cb750
    By bmartin in forum Technical
    Last Post: 03-13-2008, 01:28 PM
  5. CB750 front end on CL450???
    By KtownGreg in forum Technical
    Last Post: 08-10-2006, 07:25 AM
oif front end
oif triumph fork swaps
