CB350 K4 fork replacement
This is a discussion on CB350 K4 fork replacement within the General forums, part of the Caferacer.net Forums category; Looking to replace the stock CB350 K4 forks with a style that is cleaner, i.e. without the painted shrouding so that just the upper steel ...
Results 1 to 4 of 4
    jwhombel's Avatar
    Looking to replace the stock CB350 K4 forks with a style that is cleaner, i.e. without the painted shrouding so that just the upper steel and bottom aluminum tubes show. Prefer forks that will allow the current front axle and fender to fit without modifications. Any ideas appreciated!
    why not just take the shrouding off? IIRC the forks are the same underneath as other forks, the "shrouds" are just covers (oh and the headlight mountig ears so you will need to replace those). If not, I beleive the cb350F front disc brake setup is a bolt on if you get the triple trees.
    LiLBull's Avatar
    Look at my pics of "WAR HORSE" it had all that on it reflecters rubber garters,headlampmount /shroud .As Geeto says. Loosen the pinch bolts and brake lines take off front wheel and walla they slip off and you have the stripped down caferacer look.And the top tree just strip off the paint and you have that aluminum casting naked too!!.
    George
    Look at omars dirt tracker,or old bike barn for headlamp mounts that slip on where the clipons also fit and you are, cafenated to the max on your bike, in the front! Now on to seat !!whoa hooooo!!
    Edited by - LiLBull on Nov 15 2005 06:23:54 AM
    LiLBull's Avatar
    so what happened youve left us hanging ...?
  1. CB350 Replacement Shocks
    By dtgiven in forum Technical
    Last Post: 03-08-2011, 06:22 PM
  2. 1969 cl175 sloper replacement fork gaiters.
    By nic579 in forum Technical
    Last Post: 02-19-2011, 07:25 AM
  3. Replies: 46
    Last Post: 11-23-2010, 09:11 AM
  4. CB350 Replacement Carbs
    By johnc in forum Technical
    Last Post: 09-02-2009, 09:36 AM
  5. cb350 replacement mufflers?
    By Indie - Go - Rock in forum General
    Last Post: 03-09-2009, 11:56 AM
cb 350 fork tubes
cb 350 front fork tube
cb350 fork tube
cb350 fork tubes
cb350 fork tubes replacement
cb350 naked forks
cb350 replacement forks
cb350k4 fork tubes
replacement front forks cb 350
