relay for turn signals?
This is a discussion on relay for turn signals? within the General forums, part of the Caferacer.net Forums category; I need a relay im thinking for turn signals? They just stay on when you turn on the switch. Am i screwed or do i ...
Results 1 to 5 of 5
    Senior Member blueandy's Avatar
    Sep 2010
    farmington, missouri, USA.
    I need a relay im thinking for turn signals? They just stay on when you turn on the switch. Am i screwed or do i just need to do a lot of searching? And one more question. Rebuild my own forks or let a shop do it? Small leak on the fork seal.
    Oh yea about the turn signals, sometimes i have to ride at night and seems the 5.0 dont like hand signals at three in the morning, but then again, the neighbors dont like me hitting 7,000 rpms after warmup either!
    CR.NET home of the douchebag motel
    Fork seals - get a manual and do them yourself. Shops don't like doing them and will charge you accordingly (same with caliper rebuilds).
    Turn signals - staying on can be a sign of low voltage. Check your charging system first. Also, if you have LED signals, a standard relay may not work due to the reduced current. If this is the case, buy a LED (or "no load") relay.
    Sep 2010
    oh no, i dont have a turn sginal relay, i need to get one, thats why the turn signals stay on. I dont have the original, i would like to get small leds for easier mount but dont know which ones i should get? any ideas?
    Sep 2008
    , , Mongolia.
    One can get generic turn signal relays at any auto parts store. Don't know anything about LEDs.
    Sep 2010
    thank you for the info about the generic turn signals relays. i was about to pay thirty five for an original, screw that
  1. LED Turn Signals
    By ccantagallo in forum General
    Last Post: 12-20-2012, 12:40 AM
  2. Aftermarket turn signal relay for CB360T
    By Cursh in forum Technical
    Last Post: 06-03-2012, 11:28 AM
  3. Turn Signals
    Last Post: 06-22-2011, 10:25 PM
  4. Turn signals?
    By Blais in forum General
    Last Post: 07-19-2009, 02:46 PM
  5. Turn signals?
    By clzay in forum General
    Last Post: 03-16-2006, 10:35 AM
