spark plug seller?
spark plug seller?
This is a discussion on spark plug seller? within the General forums, part of the Caferacer.net Forums category; wheres the best place to get plugs online? And also is there anything that burns hotter than the ngk b 8es that come stock in ...
Results 1 to 5 of 5
    Senior Member blueandy's Avatar
    Sep 2010
    farmington, missouri, USA.
    spark plug seller?
    wheres the best place to get plugs online? And also is there anything that burns hotter than the ngk b 8es that come stock in my bike? Thats what im running now
    CR.NET home of the douchebag motel
    Senior Member midge's Avatar
    Nov 2007
    , , USA.
    http://www.sparkplugs.com/
    yea b7es, b6es
    BUT why would you ever want to run such a hot plug?????
    Mar 2006
    south Orange County, CA, USA.
    Andy, putting in a hotter plug is only a good idea under some circumstances. You want the heat range that is the best compromise between hot enough (hot enough to burn off fouling deposits in the combustion chamber before they build up) and cool enough (cool enough to prevent excessive pre-ignition or detonation). If you slap a plug in there that is hotter than the manufacturer recommends, and your motor starts pinging and basically eating itself alive, that would be bad.
    Is your motor getting old? I have used hotter plugs to nurse along an old motor that is burning oil and coking up badly. It's only to tide me over until I have the motor rebuilt though.
    High performance riding (racing) can require colder plugs than stock. To prevent detonation.
    Senior Member 44dwarf's Avatar
    Sep 2010
    North Central, Mass, USA.
    I could not belive it but Advanced Auto had plugs in stock and $1.50 cheaper then any other place on line for my 02 GSXR. Order on line and picked up local next day.
    USCRA #944
    WVRC #44
    www.wvrclub.com
    Sep 2010
    Boston, Georgia, USA.
    what about using a higher octane gas (100LL) and a hotter plug? any performance to be gained?
  1. CB Spark Plug Banter
    By busapilot in forum Vintage Motorcycle Racing
    Last Post: 12-31-2011, 04:30 AM
  2. spark plug clearance
    By imslow in forum Technical
    Last Post: 05-26-2008, 06:57 PM
  3. Spark plug choice
    By lonewolf in forum Technical
    Last Post: 04-13-2008, 06:44 PM
  4. NGK spark plug thingies
    By aaron in forum Technical
    Last Post: 03-22-2005, 12:29 PM
  5. yeah, can I get a spark plug?
    By JD in forum General
    Last Post: 12-05-2003, 06:13 PM
