cb350g brake rotors
cb350g brake rotors
This is a discussion on cb350g brake rotors within the General forums, part of the Caferacer.net Forums category; i'm new to this site. and would like to know if anyone knows where to find a drilled rotor for and 73 cb350? thaks eric...
Results 1 to 4 of 4
    Senior Member Eric750's Avatar
    , , USA.
    cb350g brake rotors
    thaks
    eric
    I assume you are talking about a cb350F as they came with discs. The cb350 twin mostly came with drums (there were a few disc bikes toward the end of the run...using 350F discs).
    The only place is to drill it yourself. Get a drill press (or beg a friend) and some hardened bits. Don't forget to chamfer the ends.
    There is a how to on the web somewhere, Give me a day to find it and I'll post it here.
    LiLBull's Avatar
    hey Eric welcome to the board "CAFE THE NATION"
    alot of early eighties bikes have drill rotors you may have to hunt and scour for a model that will fit look in honda later models and see .thats if your doing it for looks if your doing it for better brakes a up grade in brake pad compound may be the ticket put you dont want a true race pad as they take a lot of warming up under hard use to make them work not what you need on the street.try vintage brake, George
    http://www.vintagebrake.com/index.html
    Edited by - LiLBull on Nov 20 2005 3:30:17 PM
    Edited by - LiLBull on Nov 20 2005 3:33:14 PM
    LiLBull's Avatar
    check this out it may help you http://eindiancompanies.com/howto/howtorotor.htm
  1. Trying to locate hard shifting problem CB350G
    By twosixtk in forum Technical
    Last Post: 06-11-2011, 08:13 PM
  2. 1973 CB350G - Need help!
    By warnereg in forum Technical
    Last Post: 04-13-2011, 09:34 PM
  3. wanted: 1987 Honda RS125 Brake Rotors Front & Rear
    By texmawby in forum Vintage Motorcycle Racing
    Last Post: 04-02-2009, 12:03 AM
  4. ebc brake rotors
    Last Post: 10-07-2008, 07:48 PM
  5. Drilling Brake Rotors
    By Ease in forum Technical
    Last Post: 04-17-2007, 08:53 PM
cb350 drilled brake rotor
cb350g brake
