52mm Velocity stacks
This is a discussion on 52mm Velocity stacks within the General forums, part of the Caferacer.net Forums category; Need some. Links pl0x....
Senior Member
Senior Member
OK, I found it.
It says on the Box--CDC Malossi Prese aria a cornetto, made in Italy, Calderara Di Reno (Bologna)
It is polished alloy, OD on the end where the female threads are is 55mm, ID before the threads start is 52mm. Diameter at the Bellmouth is about 77mm. It is pretty flat, about 22mm from front to back.
I have a pair. If I recall correctly, I won these at a uscra event, and they were donated by Vintage Cosmo.
If you want them, just $10 delivered to your door.
Jack
Senior Member
OK, I found it.
Jack
Senior Member
Wow, coolio. I need 4 though. I still take em if you want to sell them, though.
Senior Member
Senior Member
Shoot me your address and I will send them out. I double checked the ID of the threaded end and It could be a little bigger than 52mm, but not 53mm. It is a female thread. Between my old eyes and old micrometer could be a hair off.
Senior Member
Senior Member
Roger that. You has paypal?
Senior Member
Senior Member
Now, anyone have a link to a set of 4 52mm velocity stacks?
- You may not post replies
- You may not edit your posts
Forum Rules
By crashkillsvince in forum Technical
Last Post: 12-15-2010, 04:29 PM
By keith99 in forum General
Last Post: 01-20-2010, 07:33 PM
By Whitehurst in forum General
Last Post: 01-04-2010, 10:01 PM
By gryffin in forum Wanted
Last Post: 12-25-2009, 09:43 PM
By ct77 in forum Technical
Last Post: 10-21-2007, 05:16 PM
52 mm velocity srack
52 mm velocity stack
52 mm velocity stacks
52mm bellmouths velocity stacks
52mm motorcycle velocity stacks
52mm velocity stack
53 mm velocuty stacks
53mm velocity stacks
