crazy swing arm
crazy swing arm
This is a discussion on crazy swing arm within the General forums, part of the Caferacer.net Forums category; Whats up with the swing arm on this bike pretty crazy set up....
Results 1 to 10 of 15
Thread: crazy swing arm
    Senior Member grinch77's Avatar
    Mar 2008
    Coweta, Oklahoma, USA.
    crazy swing arm
    fubar. check some 70's kawasakis. kr750?
    WERA 119
    CCS 119
    CRA 119
    AHRMA not anymore
    Evan Esar
    Fairfax, VA, USA.
    Fairfax, VA, USA.
    The bike was built by the Burning Blood Racing Team to compete in the All Japan Road Race Championship GP250 class.
    Fairfax, VA, USA.
    The parallelogram rear suspension is nothing new
    Moderator jbranson's Avatar
    Feb 2004
    , , South Sandwich Islan.
    I say it's a crime against nature and disturbs my world view. Please remove it.
    Nov 2008
    It was used on a lot of bikes in early 70's.
    You keep constant chain tension if links are correct length, or, you can set up for rise, squat and anything in between.
    It should work even better with modern dampers.
    Only real issue is extra weight and a lot of pivots to wear
    Mar 2008
    thanks for the explanation pj.
    Senior Member jaguar's Avatar
    Dec 2005
    Albany NY
    kinda cool idea
    I am Derby\'s Bitch
    Feb 2006
    So you could set it up so there's negligable wheelbase change throughout wheel travel.
    Height of the frame attachment points has an effect on how the chassis "sees" power. Notice the modern one has longer arms on the birdgage. Off the top of my head I'd say higher the top frame attachment point is the less wheelie prone the bike.
    The modern bike, assuming the shock's mounted how I think it is, the shock isn't loaded by accel/decel forces. The old bike the shocks are actually more loaded by accel than they would be in a conventional setup.
    It's basically a four-bar no different than a dirt late model or a pro stock drag car. Only thing limits what you can do on a bike is that any change that makes traction under power causes it to unload on decel. i.e. can't get near as radical as you can w/a car.
  1. If I was crazy before...
    By LarryBones in forum General
    Last Post: 11-28-2011, 11:48 AM
  2. Am I crazy?
    By mickey356 in forum General
    Last Post: 08-12-2011, 02:10 PM
  3. Maybe I'm Crazy
    By catboy in forum General
    Last Post: 03-03-2011, 01:41 PM
  4. would I be crazy to buy a.
    By nic579 in forum General
    Last Post: 05-31-2010, 10:07 PM
  5. Crazy Roads
    By Pete Casper in forum General
    Last Post: 12-04-2009, 11:38 PM
cafe racer with crotch rocket swing arm setups
