75' 550F Build
75' 550F Build
This is a discussion on 75' 550F Build within the General forums, part of the Caferacer.net Forums category; I haven't posted for a while and decided now that I have started tear down my 550F I would share my journey and ask for ...
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: 75' 550F Build
    Senior Member Tews19's Avatar
    Jun 2011
    , WI, USA.
    75' 550F Build
    I haven't posted for a while and decided now that I have started tear down my 550F I would share my journey and ask for a few suggestions....
    1- I want to improve my suspension, do I go with progressive springs with a rating of 100? I think that is how it was worded when I was looking it up..... I will be going with Hagons in the rear, is there a specific type of Hagon's I should be looking for? I will be either looking for a better swing arm or sending mine it to the gentleman who wrote the book on CB750's to improve the bushings and seals. I bought a new lower triple, Should I go with Timken tapered bearings?
    2- i was advised to stick with a stock sprocket and get a new chain... Any suggestions to keep it stock or to go with a different set up?
    3- The rear wheel is heavy as hell... Any modifications I can do to lighten it or look into a different rim? I like the size of the rear currently and do not want to go up in size... Also, what type of bearings should I go with or kepe it stock? I think 36 years old bearings might need to be replaced...
    4- Front brake, what should I do? i read I can reverse the brake and have it on the inside of the fork rather then the stock front of the fork.. I read it helps with braking and less stress on the bike...
    If anyone has more suggestions to assist with breaking and suspension I would greatly appreciate the help...
    here is a pic of the day I picked her up..
    After I removed the fairing
    Todays progress....
    Senior Member jaguar's Avatar
    Dec 2005
    Albany NY
    Good to see you are still super excited about all this
    I am Derby\'s Bitch
    Dec 2005
    Albany NY
    I am Derby\'s Bitch
    Jun 2011
    , WI, USA.
    MAN, I was trying to think who has the signature of "There is the right way, the wrong way and the british way to do anything!" I have been excited thanks to this site when I was getting into bikes... I have 2 550's and the KZ which most of you were right when you all told me the SR blows.... It does...
    Jun 2011
    , WI, USA.
    Nov 2008
    Get a second caliper and rotor, bike really needs dual disc if you intend to ride it
    I used CB750 sohc fork tubes and springs on mine (I was working at a Honda dealers, cheapest way to go)
    I also fitted CB750 rear shocks (originally Girling as they were still in business)
    When they wore out I fitted something diffe3rent but can't remember make
    I used CB750 parts for two reasons,
    1. heavier springs suited my riding better than the mushy stock springs.
    2. Fork tubes and rear shocks longer by about inch and half, stopped bits dragging on the floor when cornering
    F1 four into one exhaust brought me off a couple of times, so I had to change that as well (dropped it about 80mph one time, that was a bit scary )
    I swapped fork legs and put caliper behind fork, I think it improved handling slightly?
    This is rolling up to 100,000 miles on clock (really closer to 106,000, busted a few speedo cables over the years)
    This is how it looked around 1980 (had lots of different iterations over the years )
    Nov 2008
    Nov 2008
    Your Moms House, USA
    Give me the SR.
    Nov 2008
    Give me the SR.
    Sep 2010
    Boston, Georgia, USA.
    please...please...please dont paint that tank or the side covers...
  1. Honda cb 550f
    By Jcastanley in forum Project Builds
    Last Post: 09-23-2012, 11:56 PM
  2. Sync'd my 550F carbs
    By Tews19 in forum Technical
    Last Post: 06-01-2012, 02:09 PM
  3. FNG here, with a new build
    By scarecrow in forum Project Builds
    Last Post: 05-05-2011, 10:17 PM
  4. 76 rd 400 build (my frist cafe build)
    By jamin_mathis in forum Project Builds
    Last Post: 02-07-2010, 01:49 PM
  5. New CL350 Cafe - First Time Build Buget Build
    By kadavenport in forum Project Builds
    Last Post: 04-10-2009, 02:41 PM
