1980 Honda CB750 Problems
This is a discussion on 1980 Honda CB750 Problems within the General forums, part of the Caferacer.net Forums category; I just bought a 1980 Honda CB750 and it has a couple problems. I need to know how to fix the shifting mechanism in the ...
Results 1 to 5 of 5
    Junior Member pistonhead's Avatar
    Apr 2012
    Ashdown, Arkansas, USA.
    I just bought a 1980 Honda CB750 and it has a couple problems. I need to know how to fix the shifting mechanism in the transmission because every time I try to shift I have to push/pull the shift lever in the opposite direction just a little before I can actually shift. Its like the lever wont spring back to place so I can make the shifting smooth. Does anyone know what I can do to fix it?
    clean the 30+ years of grime from around the probably leaking shift seal?
    Senior Member oldhondacafe's Avatar
    Mar 2009
    Riverside, Ca., USA.
    just like he said, remove the shift pedal and the sprocket cover, (only 4 bolts) and dig it out. otherwise the shaft could be bent from a crash and be binding in the cover. either way you got to git into it to see. easy fix either way.
    \'78CB750f,\'76 cb500t,\'5-CB/CL450 basketcases,\'68 CL175,\'66 CA77/in a CL72 frame,\'1971 DT1f,1988cbr1000f,1987cbr1000f
    Nov 2008
    Return spring could be broken, but, lever tends to flop around when that happens.
    Easy fix, remove clutch cover and clutch
    Apr 2012
    Thanks for the info on that part. But now im trying to put a speedometer on my bike and cant seem to figure out the size of the cable nut for both a new speedometer and for the part on the bike to attach it to.
  1. Headlight problems cb750
    By kawiracer in forum General
    Last Post: 06-01-2018, 10:29 AM
  2. general problems on 1980 cb750
    By btuck in forum General
    Last Post: 05-04-2012, 11:19 AM
  3. 1980 Honda CB750 Bachelor Bike
    By benjamin.bb in forum General
    Last Post: 02-03-2012, 11:20 AM
  4. 1980 Honda CB750 Custom
    By Tews19 in forum General
    Last Post: 06-08-2011, 06:44 PM
  5. Idle problems with the CB750....
    By midnight08 in forum Technical
    Last Post: 11-14-2008, 12:40 PM
1980 honda cb 750 problems
1980 honda cb750 motorcycle how to shift
1980 honda cb750 problems
cb750 transmission problems
cb750k honda common problems
common problems with a 1980 cb750
how to troubleshoot a cb750
problems with honda cb750
what is the shifting of a 1980 cb 750 custom
