Triumph Engine Noise
This is a discussion on Triumph Engine Noise within the General forums, part of the Caferacer.net Forums category; I'll confess, I'm only 23. That's not necessarily the problem, however I can say I haven't been around long enough to be able to listen ...
Results 1 to 5 of 5
    DubC350's Avatar
    Mar 2006
    I'll confess, I'm only 23. That's not necessarily the problem, however I can say I haven't been around long enough to be able to listen to the Triumph in my barn and tell you if it sounds like it should.
    It started fine a few days ago, while running it makes a chattering metallic sound... did the ol' screwdriver to the ear trick and thought perhaps the valves slamming open & closed? A strange rapid 'tinking' or chattering is the best I can describe it.
    My buddy rode it for a few days, then came cruising in the driveway claiming he had lost a cylinder. Cleaned the carbs (weird clear spherical build up? ...no idea where it came from or what it is as the engine was recently professionally rebuilt)and they bleed beautifully now, went over everything else in the area... Now she won't start. Kicked for 30 minutes, bump starts, everything.
    Today my buddy plans to get it started and seek the advice of (older) friends who know what the thing should sound like. Thought I'd ask around here too. I know this is a little vague, hopefully one of the local Triumph guys gets a listen to it today. Any ideas here?
    Oct 2004
    matthew,
    hopefully one of the old guys you refer to in west chester is snuffy smith. if not, find him as he has at least 5 triumphs in his collection. also craig charles in abington or jesse morris in phoenixville are knowledgable dudes.
    word!
    "dude, my boots feel like they are filled with rain slushies!"
    DubC350's Avatar
    Mar 2006
    Oh, he's on the list. Sonny in Rising Sun too.
    Oct 2004
    then your in good shape. tell him tex said hi!
    Moderator joe c's Avatar
    Mar 2002
    , , Turkey.
    did you check to see if the valve adjusters had backed off??
    they are notorious for that.
  1. not a noise we like to hear...
    By ukTony in forum General
    Last Post: 01-28-2012, 10:00 AM
  2. Engine noise diagnose
    By stevecole33 in forum Technical
    Last Post: 08-14-2011, 09:47 AM
  3. Starting noise
    Last Post: 07-07-2011, 09:41 AM
  4. Wanted: 885cc triumph engine
    By dbr0051 in forum Wanted
    Last Post: 12-04-2007, 09:58 AM
  5. Excessive cam chain noise?
    By ROSKO in forum Technical
    Last Post: 08-12-2005, 10:10 AM
