First Build! Help with turn signals
This is a discussion on First Build! Help with turn signals within the General forums, part of the Caferacer.net Forums category; Hey guys, I have a 78 gs550 that I picked up for dirt cheap. It's my first bike ever and I am loving the cafe ...
Results 1 to 10 of 10
    Junior Member avanman's Avatar
    Apr 2013
    Wisconsin
    Hey guys, I have a 78 gs550 that I picked up for dirt cheap. It's my first bike ever and I am loving the cafe style. One issue I have ran into is converting my turn signals to LEDs. I am assuming I need a resistor and can't just plug and play? If a resistor is needed? How do I know what kind or size??
    Just go buy an LED turn signal solenoid. They are all over eBay. Match up the picture to what you have (should be three wire square type).
    Senior Member dirkchecken's Avatar
    Jan 2012
    signals, don't talk about signals,
    I like my shocks like I like my women. Cheap and Chinese.
    It is also sometimes called a flasher relay.
    Member Chev's Avatar
    Aug 2012
    NYC, , .
    If you install resistors it negates the benefit of low draw of the leds, so your modification would be only for show.
    Apr 2013
    Wisconsin
    Thanks a lot guys!! Very helpful!
    Senior Member jaguar's Avatar
    Dec 2005
    Albany NY
    Who needs blinkers?
    I am Derby\'s Bitch
    Apr 2013
    Wisconsin
    Another question. I am assuming I will need on solenoid per corner? Or just one for all four turn signals.
    Senior Member Teazer's Avatar
    Mar 2010
    , IL, .
    Quote Originally Posted by avanman View Post
    Think about it for a moment. What does a stock bike or car have - One per lamp or just one?
    one solenoid per bike. You do NOT need four. you do need a manual so you can open up the wiring diagram portion and find the flasher solenoid.
  1. LED Turn Signals
    By ccantagallo in forum General
    Last Post: 12-20-2012, 12:40 AM
  2. Turn Signals
    Last Post: 06-22-2011, 10:25 PM
  3. Aftermarket Turn Signals?
    By jimd118 in forum General
    Last Post: 07-27-2010, 11:15 PM
  4. Turn signals?
    By Blais in forum General
    Last Post: 07-19-2009, 02:46 PM
  5. Turn signals?
    By clzay in forum General
    Last Post: 03-16-2006, 10:35 AM
cafe racer blinker only switch
cafe racer blinkers
cafe racer turn signal
cafe racer turn signal relocation forum
cafe racer turn signals
caferacer turn signals
good blinkers for cafe racer?
how to wire cafe racer turn signals
three wire cafe racer turn signals
Tags for this Thread
