'59 Ducati 175
'59 Ducati 175
This is a discussion on '59 Ducati 175 within the General forums, part of the Caferacer.net Forums category; My brother acquired this machine recently. Talk to me about it. See anything out of the ordinary as far as parts? Looks like it was ...
Results 1 to 4 of 4
Thread: '59 Ducati 175
    Senior Member CurbTiger's Avatar
    Apr 2009
    Portland, Oregon, .
    '59 Ducati 175
    Looks like it was prepped for the track at some time.
    I don't have any more pics yet.
    NE
    Subscribe to SIX HOT ISSUES!! of WarmPipe for only $29.99!!! Interweb NOW!!!!!
    Jun 2013
    South Lyon, MI
    ...drool...
    Jun 2008
    SE MI, USA.
    Seat is aftermarket (obviously). Looks like someone cut the rear of the frame off. Tank doesn't look like it fits right, should be lower in back? Or might just be lack of stock seat... but if I had to guess, the carb set up isn't stock and the tank is raised to clear it.
    Front hub has been cut up? On second thought... it may be a non-Ducati hub, it looks like there's a brake stay visible on the other side which wouldn't be there on the stock part. Rear sprocket looks weird too but that could just be an aftermarket part. Fork tubes have been painted (between the triples) headlight mounts are missing (and expensive if it's got clip ons). There are some spring covers that are missing too , replaced by gaitors. Headlight's obviously missing so the speedo is gone. Wiring is non-existent. I can't see what's being used as rear sets but the stock pegs are gone. I don't see a kickstart lever and who knows if the kickstart internals are still there.
    If it's a 175 don't expect much for performance. The 175 is the same family of engines as the 250 though so parts are for the most part readily available. It's not a desmo, if that matters, which it shouldn't.
    The good news is, that's a desirable tank and overall I'd say the bike could be the basis of a pretty sweet little project. It needs a lot to be streetable but I'd be happy to start with that.
    I'm guessing whoever put it together was shooting for this look... which is a project I had in mind too. I've got the engine, tank, forks, and front hub. The rest is still out there somewhere...
    Last edited by DesmoDog; 08-15-2013 at 12:18 PM. Reason: I really need to learn to type better
    -Craig
    I noticed the rims are mis matched. Non stock Alloy front and possibly stock steel rear. Front brake may not be stock either as it is heavily vented and thicker. looks like a borrani or akront on the alloy rim)
    Not familar with the intakes but the carbs look to be on a longer intake manifold and at a different angle from stock.
    I am assuming this was a TS 175 originally:
  1. NEVER! buy a ducati
    By Geeto67 in forum General
    Last Post: 10-23-2010, 03:56 PM
  2. Ducati 250
    By lovejoy in forum Wanted
    Last Post: 12-04-2007, 09:49 AM
  3. '95 Ducati 900 SS SP
    By FR in forum Bikes For Sale
    Last Post: 06-22-2007, 08:11 PM
  4. Need Ducati Help!!!
    By JackC in forum Vintage Motorcycle Racing
    Last Post: 05-06-2007, 08:52 PM
  5. 66' Ducati 250
    By magnetoczar in forum General
    Last Post: 05-19-2006, 10:44 AM
ducati 175
ducati 175 cafe racer
ducati 175 for sale
ducati 175 front hub
ducati 175 t
