Bought another bike! Yamaha xs850 special - Page 3
This is a discussion on Bought another bike! Yamaha xs850 special within the General forums, part of the Caferacer.net Forums category; "I personally own a 850 special, and I can tell you that "shaft jacking" is more a myth than a reality." Bullshit. It's all physics. ...
Results 21 to 30 of 34
Like Tree1Likes
Thread: Bought another bike! Yamaha xs850 special
  1. #21
    Senior Member Emit R Detsaw's Avatar
    Oct 2009
    Phoenix, AZ, USA.
    Bullshit. It's all physics. I've owned two XS750E and one XS1100E and I can tell you, it is real. It was so bad that a high-rpm first or second gear throttle chop would hop the rear wheel off the ground. You're either riding it like a pansy or have hard-tailed the bike.
    "The seca 650 I had for a while had no lash"
    True, to a point. It still did have a shaft-jacking effect, but was much subdued. I had one of those too.
    The first-gen Yamaha shafties used a constant-velocity universal joint, and later ones used a more traditional u-joint. I'd never heard of, seen parts of, or witnessed any Yamaha shaft final drive that locked up. Doesn't mean it never happened, but I'd say they were pretty solid from a durability standpoint.
    I believe we have run out of trolls.
  2. #22
    my GS850L was a bucking bronco. you could literally feel it rise and fall. The R80Rt beemer isn't as bad but I do get why they call all airheads rubber cows - the jacking motion and the rotational effect make for an interesting ride quality.
    A lot also depends on the condition of the bike. If you are on worn out springs and bad swingarm bushings - you are gonna feel that. If the bike is nice and tight all around it won't be as bad.
    You can get used to this stuff you know. After a while in the saddle you don't even notice it. All old vespas lean 15 degrees to the right when not on the throttle and straight up when you are. After a couple of days you don't notice it anymore.
    I've heard on more than one occasion about the XS11 final drive locking up - not sure if it was the actual final drive unit or the universal at the motor but apparently it was whilst the bike was being ridden and it locked the wheel. Apparently. Never saw it, so I won't say it's gospel.
    But I did have an XJ900 universal let go (not on me, but on the guy I'd just sold the bike to). Made quite a mess. We went halves in the repair bill because he wasn't a dickhead and swore he didn't abuse the bike.
    Senior Member Joep7's Avatar
    Sep 2011
    West MI, USA.
    Naw this lockup is common at the middle drive. Gear oil leaks into the crank and it burns up.
  6. #25
    Oct 2009
    Phoenix, AZ, USA.
    "Gear oil leaks into the crank and it burns up."
    'Splain that, Luceeee.
  7. #26
    Sep 2011
    West MI, USA.
    sorry...the gear oil from the bolt on middle drive leaks into the crank and the middle drive runs dry and eventually locks. I believe it leaks through the bearings between the final gear housing and the crank. Should have been more clear.
  8. #27
    May 2010
    murfreesboro, tn, USA.
    Hey guys, I have been messing with the bike some, but have been short on free time because I bought a house that needs some work as well.
    The motor runs on the bike, but poorly because of dirty or damaged carbs. I have a guy offering to sell me some known good mikuni's for it, so I'll probably go with those. My front brake is locked up, though, so I haven't been able to ride the bike at all yet. Does anybody know if I can just disassemble the calipers and clean them up with Emory cloth or something, replace the o-rings and call them good?
    I joined the Yamaha triples forum, so I'll ask over there, too. It also seems like a good place to find parts as well. I think I'm going to get a standard rear wheel and tank if I can, and try to find some super bike or dirt bike bars that I like.
    The seat is the last thing on the list, but it will be for sale once I figure out the direction I want to go with that.
    The bike has some Dunlop tires on it that are in good shape, but they're a couple of years old. Does anyone reccomend avon tires? I have crashed with Chinese tires before, but I can't afford the pirelli's I normally put on crotch rockets. I plan to push the limits of this bike once in a while, and sticking to the road is a good thing....
  9. #28
    Rome, GA, USA.
    Quote Originally Posted by thechief86 View Post
    Those calipers are pretty easy to rebuild if you can get the piston out. Try installing a grease fitting where the bleeder was and force it out
    with a grease gun. Worked for me a few times.
    Avon AM26s are great tires. If you want cheap tires that stick, Fullbores worked great in my Sporty.
  10. #29
    Oct 2009
    Phoenix, AZ, USA.
    So you crashed on Chinese tires before...are you blaming your crash solely on the tires?
    I've crashed on just about every brand of tire, bias, radial, cheap and damn expensive. Wasn't the tire that caused the crash.
  11. #30
    Sep 2011
    West MI, USA.
    Mikunis as in flat or round slides or cv mikunis?
  1. Yamaha YB100 special
    By ukTony in forum General
    Last Post: 04-04-2018, 10:42 AM
  2. yamaha xs850
    By nmangano in forum Project Builds
    Last Post: 06-26-2012, 07:38 AM
  3. My First build Yamaha XS850 1980
    By vodkalex in forum Project Builds
    Last Post: 06-14-2009, 10:06 PM
  4. 79 yamaha 650 Special
    Last Post: 06-30-2008, 02:33 PM
  5. yamaha xs 400 special 2
    By speeds in forum Technical
    Last Post: 01-22-2007, 04:34 PM
1980 yamaha xs850
1980 yamaha xs850 review
xs850 cafe
xs850 cafe racer
yamaha 850 special
yamaha xs850
yamaha xs850 cafe
yamaha xs850 cafe racer
yamaha xs850 review
