Bought another bike! Yamaha xs850 special - Page 4
This is a discussion on Bought another bike! Yamaha xs850 special within the General forums, part of the Caferacer.net Forums category; I truly blame my own carelessness for my crash, although with better/stickier tires my delayed reaction to the guy driving on my side of the ...
Results 31 to 34 of 34
Like Tree1Likes
Thread: Bought another bike! Yamaha xs850 special
  1. #31
    May 2010
    murfreesboro, tn, USA.
    I truly blame my own carelessness for my crash, although with better/stickier tires my delayed reaction to the guy driving on my side of the road In a curve might not have resulted in my bike sliding out from under me.
    the carbs he has are the round slide smooth bore 29's I believe. I had a set on my old kz1000, and they were great. These arethe same thing just set up for a yammy triple.
    Thanks for the grease gun tip! The pistons slide out pretty well with just the master cylinder, just won't slide back in to let go of my rotor. I opened the bleeder and they still wouldn't let to, so I blame the caliper rather than the hose, although I will replace all the hoses with stainless next month when I have some extra scratch...
  2. #32
    Junior Member 68vistacruiser's Avatar
    Sep 2013
    Shorewood, IL
    Quote Originally Posted by Emit R Detsaw View Post
    "I personally own a 850 special, and I can tell you that "shaft jacking" is more a myth than a reality."
    Bullshit. It's all physics. I've owned two XS750E and one XS1100E and I can tell you, it is real. It was so bad that a high-rpm first or second gear throttle chop would hop the rear wheel off the ground. You're either riding it like a pansy or have hard-tailed the bike.
    "The seca 650 I had for a while had no lash"
    True, to a point. It still did have a shaft-jacking effect, but was much subdued. I had one of those too.
    The first-gen Yamaha shafties used a constant-velocity universal joint, and later ones used a more traditional u-joint. I'd never heard of, seen parts of, or witnessed any Yamaha shaft final drive that locked up. Doesn't mean it never happened, but I'd say they were pretty solid from a durability standpoint.
    I drove my 850 to work the other day, and as I was driving it I thought about the shaft jacking. I cracked the throttle a few times and now I agree if you think about it then you will notice it. I can't conceive of it actually hopping the wheel off the ground, but I will agree I don't drive it like I'm on a suicide ride.
  3. #33
    Sep 2013
    Shorewood, IL
    Quote Originally Posted by Joep7 View Post
    Naw this lockup is common at the middle drive. Gear oil leaks into the crank and it burns up.
    Unless I'm mistaken, the XJ900 shares the same engine design as the 650, and the 650 does not have separate oil for the middle gear like the triples and the 1100.
    Junior Member binrocha's Avatar
    Oct 2014
    i just finished my 850 special, i kinda like the way it looks... & its my bike, i call it whatever i want... cafe, bobber...rat bike...
  1. Yamaha YB100 special
    By ukTony in forum General
    Last Post: 04-04-2018, 10:42 AM
  2. yamaha xs850
    By nmangano in forum Project Builds
    Last Post: 06-26-2012, 07:38 AM
  3. My First build Yamaha XS850 1980
    By vodkalex in forum Project Builds
    Last Post: 06-14-2009, 10:06 PM
  4. 79 yamaha 650 Special
    Last Post: 06-30-2008, 02:33 PM
  5. yamaha xs 400 special 2
    By speeds in forum Technical
    Last Post: 01-22-2007, 04:34 PM
1980 yamaha xs850
1980 yamaha xs850 review
xs850 cafe
xs850 cafe racer
yamaha 850 special
yamaha xs850
yamaha xs850 cafe
yamaha xs850 cafe racer
yamaha xs850 review
