Questions about tire/wheel size and handling
This is a discussion on Questions about tire/wheel size and handling within the General forums, part of the Caferacer.net Forums category; I'd like to know more about the effects and trade-offs of different tire and wheel sizes, specifically in handling characteristics and ride quality. Does anyone ...
Results 1 to 10 of 16
Like Tree1Likes
Thread: Questions about tire/wheel size and handling
    Member scottshaffer's Avatar
    May 2012
    , Texas, USA.
    I'd like to know more about the effects and trade-offs of different tire and wheel sizes, specifically in handling characteristics and ride quality. Does anyone know of any books or internet resources that discuss this in detail?
    Thanks.
    Feb 2006
    It's been beat to death here. Tony Foale writes books, I've never read one.
    In general things with big tires go faster.
    Nov 2008
    Your Moms House, USA
    So get 21 inch cokers. Front and rear.
    A more specific question might get a more useful answer. Generally speaking I like wider tires than most people, up top a point, but I know why I like them and others might not.
    WERA 119
    CCS 119
    CRA 119
    AHRMA not anymore
    Evan Esar
    Are you talking differences between front and back? Or differences as a whole? Differences in width or in height?
    a lot depends on the bike. For some reason twins running on dirt/flat track tend to do well with 19" front and rear, but motocross uses 21" and 16" or 18", and motards use 17" front and rear. 17" also seems to be the popular road race size but that may have to do more with access to modern rubber on older bikes.
    Senior Member Big Bad Bob Dog's Avatar
    Apr 2009
    Brooklyn, NY.
    There are a million variables in this. So much so that even tires companies and the manufacturers still have a shit load to discover. A small wheel the same width may turn in faster, a taller wheel that is narrow may turn in faster. A wider tire with a certain tire pressure (I know in proddy 250 2T V 400 4T teams would run their pressure as low as 15PSI in the rear) will have a bigger contact patch. Rossi and most of the GP field run 16.5 inch tires instead of conventional 17" to get the tires wider but retain the turning speed into a corner. Stoner often ran a 16" front when he was at Ducati.
    A larger rear wheel/tire will also gear the bike down. There is so much to talk about here. Whats the example you need help remedying?
    That's like, your opinion, man.
    Even when you get your head around all this there's the possibility that putting modern sized tyres on your vintage bike is going to make it handle worse because the frame and suspension isn't up to the extra forces of stickier rubber.
    Nov 2008
    Usually the question is 'how big can I go' if that's what you mean, just use search
    May 2012
    , Texas, USA.
    Thanks for all the responses.
    You're probably right, but I was hoping to understand the basic principles and guidelines first, and then have the ability to apply them to specific situations. Having said that, I have a 2005 EVO sportster that has a 16" rear wheel and a 21" front. The 883 of the same year comes with a 19" front. I took a look at the XR1200 and it has a 17" rear and 18" front. I'd like to systematically improve the bike's handling (rear shocks, fork springs, tires and wheels).
    All of the above.
    Quote Originally Posted by Big Bad Bob Dog View Post
    See my response above.
    Nov 2008
    Then there's also the question on tire profile.
    The 17" and 18" combo of the XR is a good beginning to improved handling, but tire profiles play a big part in turn-in speed. the 'round' ones are slower, the "V" shaped quicker.
  1. Wheel size questions
    By Pluto in forum Technical
    Last Post: 05-26-2015, 01:20 PM
  2. Rim Size/Tire Size Question
    By JackC in forum Technical
    Last Post: 03-07-2011, 03:43 PM
  3. Same size tire, different real size???
    Last Post: 02-05-2011, 05:25 PM
  4. Tire Size
    By ZouLou in forum Technical
    Last Post: 11-18-2008, 12:49 PM
  5. Tire Size's
    By georGe in forum Technical
    Last Post: 12-27-2006, 09:50 PM
cafe racer same size tires?
cafe racer tire size
caferacer tyre wall high size
rims sizes for hd sportster
sportster cafe racer wheel size
tire to wheel size handling
wheel size for street tracker
wheel size handling
xr1200 19 front wheel
