cl175 "turtlechaser updat pics...
This is a discussion on cl175 "turtlechaser updat pics... within the General forums, part of the Caferacer.net Forums category; Hey folks, been hangin out on another motorcycle bbs( wisconsin motorcycling .com)heres a few pics of my 72 cl175 cafe project...taken in may or so: ...
Results 1 to 5 of 5
    ace
    ace is offline
    Junior Member ace's Avatar
    May 2006
    Wausau, Wi, USA.
    Hey folks,
    Since then iv'e worked out the rearsets(both sides)installedUni pod foam filters,the tail light/turn signals/ license plate,its just too much fun to ride!...And sounds great.<img src=icon_smile_big.gif border=0 align=middle>
    "Some things are still a mystery to me,while others are much too clear..."
    Edited by - ace on Jul 27 2006 3:35:16 PM
    \"Some things are still a mystery to me,while others are much too clear...\"
    Senior Member Ditacchio's Avatar
    Sep 2005
    Brooklyn, NY, USA.
    Sure is Pretty
    bet shes pretty nimble too
    Moderator jbranson's Avatar
    Feb 2004
    , , South Sandwich Islan.
    Put on some alloy wheels, a glass tank and fenders, a couple of Kehin 24mm carbs off a SL350 K1, some real rear shocks, some 15-20wt oil in the fork, a 305 superhawk front brake....and you'll be amazed what you can do with that bike.
    ace
    ace is offline
    May 2006
    Wausau, Wi, USA.
    Thanks for the nice comments, I'm chasing a problem now .it breaks up and doesn't want to rev higher than 7,000.I swear it revved to 9,500 after I first got it running( outta the barn) .changed plugs and caps today(that didn't cure it.)(could the points be bouncing?old plugs showed brown/ tan so I don't think its all that lean.Maybe my advancer is sticking. Any ideas? you guys know these e small bore twins...
    Edited by - ace on Jul 28 2006 8:41:43 PM
    Feb 2004
    Ace,
    In stock form they should rev clean to about 10,000+. If they don't is almost always the usual culprits...condensor, coil, plugs or carbs. Some dirt could have come loose and plugged up something in the carbs.
    Typically...as a matter of course you should replace the points and condensor...they are "consumable" items that need routine replacement. While you are at it pull of the advancer and clean it up and oil it.
    And of course typical barn bikes have all kinds of garbage in the tank, petcocks and carbs that will need to be cleaned out.
    Those bikes make most of their power at 7000+ rpm...so you want it run good up there.
    Check out my site here: http://www.jrbranson.com/HondaRacer/mainpage.htm
    for some ideas of what you can do with the bike.
  1. Help! cl175
    By PRO_Crastinator in forum Wanted
    Last Post: 07-14-2010, 11:56 AM
  2. need CL175 pics
    By robin1731 in forum General
    Last Post: 06-30-2010, 07:18 AM
  3. 73 CL175
    By Pinche Chingadera in forum Project Builds
    Last Post: 04-25-2009, 02:28 PM
  4. 72 CL175
    By Spyderlock in forum Project Builds
    Last Post: 02-06-2009, 07:56 AM
  5. Some CL175 help
    By sammydafish in forum Technical
    Last Post: 09-17-2008, 09:06 PM
72 cl 175
cl 175 pics
cl175
cl175 cafe
cl175 cafe racer
