72 cl175 jetting advice...
This is a discussion on 72 cl175 jetting advice... within the General forums, part of the Caferacer.net Forums category; Mods: this should probably be in "technical" forum please feel free to cover my mistake and move itas you see fit... Got the (sticking advancer) ...
Results 1 to 2 of 2
    ace
    ace is offline
    Junior Member ace's Avatar
    May 2006
    Wausau, Wi, USA.
    Got the (sticking advancer) idea while writing reply to my other thread.,I sprayed it with wd 40 and ran it out on an empty backroad. it still breaks up at 7,000 rpm. I changed my grip and make sure the throttle is wtfo.in top, it breaks up pretty bad, BUT if I back off slightly I pick up a few more rpm(by stock tach and ear)back home the brand new plug electrode( the bent one ) is light gray.I figure the main jet is too lean. Here's the specs: carbs: stock original keihins,
    air filters: uni foam sock hangin nekkid in the breeze.
    pipes: stock cl high pipes, muffler cut off at the muffler , jc whitney internal baffle installed in each straight pie,6" chrome straight extenstions to trim whitney baffle and hacksawed original pipes.
    Do you guys have any jetting recommendations ?What do you run with open pipes and pod filters?
    "Some things are still a mystery to me,while others are much too clear..."
    Edited by - ace on Jul 29 2006 01:19:05 AM
    Edited by - ace on Jul 29 2006 01:23:38 AM
    \"Some things are still a mystery to me,while others are much too clear...\"
    Moderator jbranson's Avatar
    Feb 2004
    , , South Sandwich Islan.
    Ace...stock main jets should be around 98. With you mods you might want to go up to about 100..wouldn't think any higher. Try raising the needle ( lower the clip) one notch and see what it does.
    Before doing any jetting work you really need to go through the ignition and carbs to make sure everything is right. New points, new condensor (condensor can really screw things up), make sure the carbs are nice and clean.
  1. What to do for jetting??
    By racemx51 in forum Technical
    Last Post: 07-17-2011, 12:47 AM
  2. advice on gearing and jetting`
    By mezwrench in forum Vintage Motorcycle Racing
    Last Post: 06-22-2010, 04:02 PM
  3. jetting
    By motogp18 in forum Technical
    Last Post: 06-22-2010, 08:24 AM
  4. jetting advice - idles rough :)
    By kerosene in forum General
    Last Post: 12-15-2009, 04:40 PM
  5. Jetting ??
    By hogsnhondas in forum Technical
    Last Post: 06-09-2008, 06:43 AM
cl 175 cafe jets
cl175 jetting
cl175 stock jets
