Norton Featherbed frame info... - Page 2
This is a discussion on Norton Featherbed frame info... within the General forums, part of the Caferacer.net Forums category; Geets, the 75 may not have been as bad as an early one but 2 times nothing is still nothing. Mine was a 1975 and ...
Results 11 to 20 of 29
  1. #11
    Senior Member o1marc's Avatar
    Sep 2012
    Dawsonville, Georgia, USA.
    Geets, the 75 may not have been as bad as an early one but 2 times nothing is still nothing. Mine was a 1975 and when throwing it from a left hand lean into a right hand lean would throw the thing into a serious tank slapping wobble. I ended up crashing hard doing that last time I rode the thing before totaling the thing out. That wreck is a whole chapter in the book my friends think I should write. It was an interesting night.
    www.CreativeCandy.org
  2. #12
    pay close attention to the thing in denco's guide: bigger frame bolts help. this means the engine is a partially stressed member in the frame. On the later h1's the engine is rubber mounted, just so you know.
    I have seen guys put kawi triple engines in 1980's Zx6R ninja chassis before. To me that's the move. Why the 1980s? because the frames are wishbone but use a lower steel engine mounting cradle that you can easily weld to if needed and therefore doesn't use the engine as a stressed member. With that setup you'd be pretty close to what a formula 1 (now motoGP) 500cc two stroke was in the early 1980s.
    Nov 2008
    Early Yamaha FZR600 , Suzuki Katana 600 or Suzuki GS500 rolling chassis, perimeter frame, all steel, upgrade suspension and it will be a nice bike
    at least it would change direction as compared to say a Z1 where it took directional changes as light suggestions and filed them in the round file.
    yeah the 73-75 frame still needs work. Even a 76 KH500 frame which added most of the bracing mentioned in denco's guide still needs work. But an early h1 frame you could feel wind up underneath you. I have a 1971 bare frame and I can flex it by hand in a lot of spots. I think where kawasaki made the mistake is they made the 73-75 engines rubber mounted and they still used the old small bolts which means the engine was now less than the stressed member it was before. They gave the neck extra suppot but didn't add support to the cradle, esp the needed cross braces (which they did add in 1976). The swingarm wasn't great either, too small. It's another part you can easily flex by hand. The whole frame has a tendency to wind up on you in hard cornering (the cradle tries to shift laterally) and when you transition it "springs" back to shape as you cross the neutral point - hence the wobble.
    Senior Member TCed's Avatar
    Dec 2011
    traverse city, mi, USA.
    what was done to the frames on bikes Duhamel rode ?
  7. #16
    Quote Originally Posted by TCed View Post
    Mojo Kawasaki - DuHamel Works H2R
    Mojo Kawasaki - 78 KR750 (Yvon DuHamel)"
    notice the dunstall forks....sexxy but terrible:
    Kawasaki H1R W 500 (1974) | Classic Racing Motorcycles
    Sep 2012
    None of those show them with the fairing?
  11. #20
    that's kind of the point...so you can see the frame details. those kawi fairings are huge and cover a lot.
  1. new norton tipe frame we are building
    By walker brothers in forum Project Builds
    Last Post: 06-04-2012, 05:48 AM
  2. 1963 Norton Electra 1962 Norton Navigator $300
    By nic579 in forum Bikes For Sale
    Last Post: 10-08-2011, 10:36 AM
  3. featherbed frames
    By raven in forum General
    Last Post: 10-07-2009, 11:26 AM
  4. sportster featherbed frame kit
    By dracken1 in forum Project Builds
    Last Post: 06-22-2009, 08:48 PM
  5. Frame painting info/links?
    By putnaja1 in forum Technical
    Last Post: 05-07-2006, 10:50 AM
disc brake forks for a norton atlas featherbed frame
featherbed box swingarm
featherbed frame rubber mounting
new norton featherbed frames
norton featherbed cafe
norton featherbed longer shocks
notorious featherbed frame
swingarm for featherbed trame
what ever happened to the domiracer
