Turn Signal Question
This is a discussion on Turn Signal Question within the General forums, part of the Caferacer.net Forums category; Hey guys, I have a quick question for you. When i purchased my 1977 KZ750 twin it came with a sweet white fairing on the ...
Results 1 to 6 of 6
    Junior Member PodDoc's Avatar
    Mar 2016
    Lincoln, NE
    When i purchased my 1977 KZ750 twin it came with a sweet white fairing on the front. As cool as it is, its not the look I'm going for. So, upon taking it off I noticed the front turn signals are gone. Since there are no turn signals the rear ones no longer flash, they simply stay lit without blinking (pot smokers, feel free to quote that). I believe this is because the resistance from the front signal lights is not there. So, I checked with the local laws here in Nebraska and you are not required to have turn signals.
    Here's my question, is there a way to bypass the front signals and just have the rear ones working? I'm assuming I might be able to get this to work with a resistor on the turn signal wire but wasn't sure if you recommended this. If you think this is not a good idea then is there an aftermarket turn signal setup you might recommend. I found some original front signals on ebay but I'm not sure if there is a better way or not. Thoughts?
    Before:
    After:
    Thanks
    PodDoc
    You just need to get a no-load / LED relay unit. You can get them at pretty much any auto store for just a few $$.
    Senior Member CurbTiger's Avatar
    Apr 2009
    Portland, Oregon, .
    You're on the money about not enough load on the blinky box to make it blinky.
    Obey the Hillsy.
    As your DangerOfficer, I strongly recommend keeping front signals.
    Left turn accidents are a very common car/bike accident.
    Blinky front bits give you something of a chance when it comes to dealing with the present state of inattention to driving.
    Perhaps drivers in Nebraska are better at not driving whilst smartphoning. Or, better at multitasking. Doubt it, though.
    NE
    p.s. I suppose you could put a resistor in place of each front turn signal and keep the existing blinky box. Dunno what resistance is needed. That'd require math right now.
    Subscribe to SIX HOT ISSUES!! of WarmPipe for only $29.99!!! Interweb NOW!!!!!
    Jan 2015
    San Diego, CA
    X2 what hillsy said. Easy money
    http://pages.ebay.com/motors/link/?n...502214&alt=web
    Your front end looks relieved from that fairing.
    Looks nice.
    Mar 2016
    Lincoln, NE
    Perfect! I'll pick one up tomorrow and let you know how it goes.
    Thanks
    modern LED turn signals are 100 times brighter than the old incandescent stuff used on a lot of this 70's junk. Even the cheap Chinese ones you get off ebay are better than nothing. you will need the LED relay for them though.
    something like this is hard to beat:
    http://www.bikebandit.com/aftermarke...d-turn-signals
    $28 per pair, LED, and you can fix the shitty fake carbon fiber look with some black rattle can paint.
    If you want to keep it "vintage" these were the back in the day 1980's aftermarket signals for non-sportbikes:
    Lockhart Phillips Aluminum Series Turn Signals | MotoSport
    alloy housing makes them super durable, and if you want you can just get an LED replacement bulb. I have been seeing the round style on a lot more vintage bikes more recently:
    Lockhart Phillips USA Sport Bike Parts and Accessories
    Oh, and just so you know, if you aren't running full signals front and rear you are still expected to use hand signals. Be smart and safe, get some LED bright signals and be seen.
  1. identify turn signal
    By headcreeps in forum General
    Last Post: 02-13-2014, 02:21 PM
  2. Turn signal - Brake light
    By Glenn5 in forum Technical
    Last Post: 05-17-2011, 03:50 PM
  3. turn signal
    By blueandy in forum General
    Last Post: 02-15-2011, 04:59 PM
  4. 1975 XS 650 Turn Signal Craziness
    By spacmanspif300 in forum Technical
    Last Post: 10-08-2010, 09:03 PM
  5. Shortening turn signal stalks.
    By Saml01 in forum General
    Last Post: 09-02-2009, 09:24 AM
