81GS400 project - Page 2
81GS400 project
This is a discussion on 81GS400 project within the General forums, part of the Caferacer.net Forums category; In case you are wondering, I am not going with an army theme here just allways liked the color. Hey someone pas me the wrench........ ...
Results 11 to 20 of 29
Thread: 81GS400 project
  1. #11
    Senior Member oldschoolorange's Avatar
    Sep 2006
    Hamilton, Ontario, Canada.
  2. #12
    Senior Member LiLBull's Avatar
    Sarasota, Fl, USA.
    I like the color,old skool all the way.
  3. #13
    Sep 2006
    Haven't posted any updates here in a bit, mostly because I haven't done much. The tank is nearly done and I picked up my pod filters and rear light/plate bracket. I finally received my fairing the other day so that is getting done in the same color with the checkers down the center
    Senior Member fuzzybutt's Avatar
    Nov 2006
    columbia, south carolina, USA.
    Hell i'm so damn fat i almost extended my frontend to get it at a stock ride height when i'm on it. seriously though, great looking project bike.
    Edited by - fuzzybutt on Jan 26 2007 10:01:10 PM
  6. #15
    Sarasota, Fl, USA.
    looking good I think i see some dry spray areas ,in this shot .It may need a few coats of clear in the same brand you painted the tank so far with.I am a fan of that tank shape as well nice aggressive lines.
  7. #16
    Sep 2006
    I know It needs some more clear, I had taken some 1600 grit to the 2 coats of clear I had on it as I wanted the vynal to have good adhesion. I am going to hit it with about 2 or 3 more clears and then wet sand, polish and wax to finish it off
  8. #17
    Sarasota, Fl, USA.
    looking good just go light coats over vynil,till it builds it suchs when it trys to lift from being to wet.Like I said looks great to me.
  9. #18
    Senior Member Ditacchio's Avatar
    Sep 2005
    Brooklyn, NY, USA.
    Ok
    So heres a bunch of dumb question for you
    Did you use an adhesive vinyl sheet to do the checkers?
    to mask out the areas
    and then cut the black boxes out and spray them?
    Do you have to use special adhesive vinyl for that?
    Do you precut it and then put it on and peel it?
    Sorry for all the questions
    It looks hot and I would love to try something like that
  10. #19
    Sarasota, Fl, USA.
    you can use automotive /motorcycle vynil graghics available at a lot of body supply places and sign shops can custom make vynil grapghics to apply to motorcycle or auto paint work Also eastwood company has online how to videos and that masking chip foose uses alot of on overhaulin here is the link .You can find pre done graphics on ebay or from guys like carpys 750 website
    http://www.eastwoodco.com/jump.jsp?i...RY&itemID=1334
  11. #20
    Sep 2006
    I went down to a local auto supply place and ordered up black checker vynal decals, nothing special
olive drab spray paint
