81GS400 project - Page 3
81GS400 project
This is a discussion on 81GS400 project within the General forums, part of the Caferacer.net Forums category; check out carpy's decal set at cb750cafe.com...
Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: 81GS400 project
  1. #21
    heironymous josh's Avatar
    Jan 2007
  2. #22
    Jan 2007
    Great looking project, can't wait to see updates. Thank tank is very purdy. I want one, I'm going to search ebay right now.
  3. #23
    Senior Member oldschoolorange's Avatar
    Sep 2006
    Hamilton, Ontario, Canada.
    About damn time. I finally finished the tank.
    2 coats of primer then wet sand with 600 grit
    2 coats paint then wet sand with 1000grit
    2 more coats of paint and another wet sand with 1000 grit
    3 thin coats of clear and a wet sand with 1200
    another 2 coats of clear with another wet sand at 1200 grit
    wet sand with 1600 grit
    wet sand with 2000 grit
    G3 rubbing compound by hand
    Mothers sealer and glaze with buffer
    mothers caranuba wax with buffer
    Edited by - oldschoolorange on Jan 31 2007 8:29:50 PM
    revtune's Avatar
    Jan 2007
    If it isn't too much trouble, what are the dimensions of that tank? That tank looks perfect for my project. I mainly need the length. Thanks.
  6. #25
    Sep 2006
    I am not sure of the dimensions but I can measure them up for you when I find a tape measure
  7. #26
    sprinter666's Avatar
    Jul 2007
    Hey orange where is this project at? Just asking since i think you are the only other one on here with this bike.
    http://www.driftalliance.com
  8. #27
    Sep 2006
    The bike is currently torn apart as I dumped it and locked a rod end. It took about two months for all the parts to come in for the engine and I have been too busy to do any work on it. Now that is is winter again and I am mostly finished up with the other projects I will get back to working on it.
  9. #28
    Jul 2007
    crappy! .. ok keep us posted.
  10. #29
    Jul 2007
olive drab spray paint
