Tank sealing and painting
This is a discussion on Tank sealing and painting within the General forums, part of the Caferacer.net Forums category; Hi I am working on a new tank for my Yamaha SR500 cafe racer. It is an old Ducati tank which have been modded quite ...
Results 1 to 10 of 12
    jonaslysgaard's Avatar
    Jan 2007
    Hi
    I am working on a new tank for my Yamaha SR500 cafe racer. It is an old Ducati tank which have been modded quite a bit. It has to be bondo'ed a bit and get a new paintjob, but i have bought a 3 step tank sealant kit. My question is. Do i seal the tank before i do the bondo-job or after?
    And what about the paintjob. I lust after a basic black with gold pinstripe paintjob and would like to do it myself with rattle cans. Any tricks or ideas I could benefit from?
    Jonas
    Motobikin!
    Yamaha SR 500 cafe
    MZ TS 250 cafe
    MZ ES 150
    MZ ETZ 250
    May 2006
    Detroit-ish, MI, USA.
    I rattle-canned a couple parts on my project, sanded lightly & rubbed them out & they don't look too bad. Of course they're in my basement & haven't been outside in sunlight yet. It required a pretty thick coat of paint to work, though. As always, with any kind of paint - proper prep is the key. A coat of primer will show up any imperfections.
    Senior Member robertob's Avatar
    Aug 2006
    Long Beach, Ca, USA.
    I use lacquer from Autozone because it's easy to repair mistakes.
    Usually it goes like this on bare metal parts:
    - Sand with 180, then 320
    - etching primer, dry for a couple of days. (skip for fiberglass or previously painted metal)
    - filling primer if needed, 2-3 coats with 320 or 400 grit sanding between each coat. If it doesn't shine at this stage you've got to keep working it. Dry for a couple of days.
    - 2-3 color coats, sand between with 1000 grit. Keep going until it's all covered and no dust remains. Spray one last dry coat with as little dust as possible and shoot clear within a couple of hours.
    - 2-3 clear coats. - same as above. Don't try to make it shiny in one coat because you're guaranteed to get runs & dust in your garage. Let the final coat dry for a couple of days and sand with 1500. Then light polishing compound in a week. Wax one month later.
    I've painted a couple of cars & Vespas with proper equipment and I can honestly say you can get results that are ALMOST as good with spraypaint and some care.
    The biggest problem with spray paint is that it is non-catalyzed, so it will never be as hard as proper catalyzed acrylic enamel or base-clear. You will have to be a little more careful with spray painted parts.
    Moderator jbranson's Avatar
    Feb 2004
    , , South Sandwich Islan.
    Jonas,
    A really decent rattle can job can be done if you get the right paint. If you go to an auto parts store and get automotive touchup paint in the larger cans...and some clear coat. Put on several coats of the color, let it cure for a couple of days, wet sand it with 800 then 1200 grit. Then top coat with clear. Wet sand with 1200 if needed, polish.
    Be patient, follow the instuctions. Most of the quality of the final job will be determined by the quality of whats UNDER the paint, not the paint itself. Paint can be easily fixed in most cases..what's underneath cannot be fixed so easily.
    Moderator joe c's Avatar
    Mar 2002
    , , Turkey.
    all good advice as far as i can see. i did a rattle can job with some laquer from the local autoparts store. clear coated it and rubbing compounded it out. looked great for a long time. now i have the spray stuff to do pre-cat laq and it goes on much nicer, but the end result can look very similar. prep is key, and patience. take your time and dont rush. its a slow process bt the results can be really nice.
    Senior Member Camelhairy's Avatar
    Sep 2005
    Chester, NH, USA.
    Jonas,
    I squirt on Rustoleum and don't waste time wet sanding/polishing....I'm just going to crash and trash it anyway.
    I like my Tannermatic parts...don't need no stinkin' paint.
    FC
    Mar 2004
    Raymond, NH, USA.
    FC
    And the Rustoleum paint is fuel-proof once it dries. Some aren't.
    Feb 2004
    FC
    Frank...look at my bikes...I've gone to high quality primer only. Easy to match, easy to apply...and if you handle it a lot it gets an almost satin finish. In fact...I can repaint my bikes between races!
    Member rdrce698's Avatar
    Nov 2006
    East Quogue, new york, USA.
    +1 for Camelhairy
    Oct 2004
    earl schieb paints mine for $99.99. i love earl scheib!
  1. sealing fiberglass tanks
    By xander450 in forum Technical
    Last Post: 12-21-2011, 12:57 PM
  2. Rattle Can Tank Painting
    By JackC in forum Technical
    Last Post: 05-08-2011, 06:09 AM
  3. Gas Tank sealing.
    By nic579 in forum Technical
    Last Post: 07-06-2010, 02:20 PM
  4. Sealing polisehd Steel?
    By BrianH in forum Technical
    Last Post: 12-25-2009, 08:44 AM
  5. modern sealing and loss reduction
    By HackAsaw in forum Project Builds
    Last Post: 06-20-2008, 09:16 AM
mz etz cafe racer fuel tank
