Norvin
Norvin
This is a discussion on Norvin within the General forums, part of the Caferacer.net Forums category; Twin with down tubes removed. Like this Comet based one although I would change a few things including exhaust, brakes and frame color....
Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By Cyorg
Thread: Norvin
    Senior Member Cyorg's Avatar
    May 2014
    Norvin
    Name:  Norvin 500 Cafè Racer 01.jpg
    "Non urinat in ventum"
    the thing I struggle with on the norvin with the missing down tubes.....how is it better than a stock vincent? So the engine in a Vincent is a stressed member where the frame sections bolt to right? And the value of a F-bed is in having the engine (and thus the crank) sit in line with the axles therefore minimizing the effect the weight of the engine has on handling, right? So they lowered the engine in the frame of this one so it's close to the axle centerline, but really you could have done that with custom vincent frame sections. At this level it feels like it was just done to use norton forks and bodywork. Or am I missing something?
    Senior Member steveo's Avatar
    Oct 2013
    Colchester, England
    If you've a few quid spare you could always buy one of these. I'm sure you could get it in yellow
    May 2014
    You aren't missing anything. I don't think there is anything better than a stock Vincent on this one other than perhaps the front brake. I never really understood the twin going into the FB, not that I wouldn't like to have one if that makes sense. I suppose if you have a twin with an exploded box and a naked frame, why not. It would be so easy to just put more modern forks on the original Vincent upper frame member. The steering head is bolted to the oil tank which makes up the upper frame member. That way too don't have to dick around with a new rear head mount. The front mount is fixed and the rear is set up to accommodate for expansion and contraction of the V twin cylinders. The original rear frame member could be retained with some improved dampening or it could be replaced with something more modern. I actually like the Comet based one a lot better, although I would toss the Burman box and replace it with a Norton one.
    Edit.. some folks might argue successfully that the Road Holder forks are better than Girdraulics unless you are bolting a hack onto it.
    May 2014
    I'd like one, but you can keep the exhaust system, fairing and the yellow paint. Black, Red, Blue, or Grey please
    Oct 2013
    Colchester, England
    I really like the exhaust.
    May 2014
    How close do you live to the Bradwell power station?
    pwalo likes this.
    Oct 2013
    Colchester, England
    As the crow flies about 10 miles.
    May 2014
    10 miles down wind? (insert smiley face)
    Oct 2013
    Colchester, England
    Depends.
  1. Replies: 2
    Last Post: 01-24-2018, 07:00 PM
  2. norvin oil in frame for sale.
    By dracken1 in forum Parts For Sale
    Last Post: 03-15-2010, 03:09 PM
  3. oil in frame norvin
    By dracken1 in forum Project Builds
    Last Post: 03-01-2010, 04:13 PM
  4. NorVin at speed
    By ROSKO in forum General
    Last Post: 08-04-2008, 11:03 AM
  5. NorVin for sale, yes really.
    By ROSKO in forum Bikes For Sale
    Last Post: 02-10-2008, 12:58 AM
