1978 Kawasaki KZ 650 for $750 but two outer pistons are not firing
This is a discussion on 1978 Kawasaki KZ 650 for $750 but two outer pistons are not firing within the General forums, part of the Caferacer.net Forums category; Hi, I am new here and also new to motorcycles. I have the opportunity to purchase a 1978 Kawasaki KZ 650 for $750 but two ...
Results 1 to 4 of 4
Like Tree4Likes
  • 4 Post By Geeto67
Thread: 1978 Kawasaki KZ 650 for $750 but two outer pistons are not firing
    Junior Member ronvdm's Avatar
    Jan 2018
    Hi, I am new here and also new to motorcycles. I have the opportunity to purchase a 1978 Kawasaki KZ 650 for $750 but two outer pistons are not firing. I hope to purchase this bike to convert it into a cafe racer. Should I be concerned about the fact that it has two outer pistons that are not firing? Also, it has 35,500 miles on it. Other than that, it appears to be in very good condition. I look forward to hearing what any of you have to say. Name:  00808_4xdYdFpqz8k_1200x900.jpg
    Could be a number of things but cylinders 1 and 4 share the same coil so it's probably a shot coil, ignition pick-up / points or wiring issue. Probably a simple fix, but you dont say where you are and whether the bike has a title or not. Can be a deal breaker in some states.
    Senior Member miniman's Avatar
    Feb 2017
    Ickenham West London
    If the cylinders have good compression it can only be spark or fuel missing, nothing that expensive to fix.
    $750 doesn't seem bad at all, but prices are crazy this side of the pond. That would be a £1500 bike in the uk running or not.
    Buy it, get it running before trying to modify it and learn a new skill on the way.
    Some people here will think you have no business touching that as you dont seem to know anything about bikes yet, but i say crack on...
    buy a service manual. Actually several (Haynes, Clymer, and factory). Read it several times over. Do everything it says. buy lots of tools. Once the bike runs, rides and can get down the street under it's own power then you can think about modifying it. Figure it will take about a year.
  1. Replies: 1
    Last Post: 05-23-2016, 08:10 AM
  2. 1978 kz 650 sr......what should i do first????
    By Smiles in forum Project Builds
    Last Post: 05-06-2016, 05:30 PM
  3. Replies: 4
    Last Post: 10-16-2013, 04:24 PM
  4. kawasaki triple clutch outer release
    By TheGreg in forum Wanted
    Last Post: 08-06-2012, 02:35 PM
  5. cb 550 with 750 pistons ??????
    By weside in forum Technical
    Last Post: 02-06-2007, 07:46 AM
