1980 Honda CM400T Electric Start Conversion to Kick Start
This is a discussion on 1980 Honda CM400T Electric Start Conversion to Kick Start within the General forums, part of the Caferacer.net Forums category; I am looking for some advice on how to convert my eletric start honda cm400t to a kick start. Its a personal preference however, I ...
Results 1 to 6 of 6
Like Tree2Likes
  • 2 Post By XB33BSA
Thread: 1980 Honda CM400T Electric Start Conversion to Kick Start
    Junior Member caferacer123's Avatar
    Mar 2018
    I am looking for some advice on how to convert my eletric start honda cm400t to a kick start. Its a personal preference however, I am looking to see where to get the parts needed and helpful suggestions to consider with this modification.
    Mar 2016
    Mar 2018
    Thank you. I checked out that link that you posted but I wasn't able to find very specific information on things to look for or how to do it. I understand that you need split the crank case and get an older 1970's (preferably the 1979 Honda CM400T) crank case with the kick start hole. Is there something that I need to look for when installing the kick start lever? Or if there are any other suggestions or links that I can research to find out more about how to do this. I would appreciate it. Also if anyone knows what to consider when selecting a battery because I know it is important when deciding to do a kick start because there are high performance and conventional batteries.
    Mar 2016
    You need to do so research, of course there are things you "need to look for". It's a complete waste of time in my mind, but if you have this compulsion the link I gave you was from Honda Twins.
    Step 1: buy older kickstart 1979 cb/cm400T engine
    Step 2: swap into your bike
    Step 3: ??????
    Step 4: Profit
    Seems simple to me.
    Or you know, you could just buy an older honda like a cb350 or a cb450 that has both kick and electric start. In which case:
    Step 1: sell cm400t
    Step 2: buy something else
    Step 3: ????
    Step 4: profit.
    yup still seems simple.
    Aug 2012
    grants pass, OREGON, USA.
    dude you could out hipster the entire brawl ,learn to bump start that turd in front of every body
    you will turn heads then learn to backfire that bitch with the kill switch
    hipsters all be scatrin'
    CaTacL1sm and woodsman like this.
  1. Cb 550 kick start
    By Manny_Le in forum Technical
    Last Post: 04-15-2016, 06:26 AM
  2. 1980 cm400t won't start
    By GunneyHartmann in forum Technical
    Last Post: 07-24-2015, 11:55 AM
  3. kick start only
    By shane2007 in forum Project Builds
    Last Post: 12-23-2012, 09:20 AM
  4. 1980 Honda cm400e won't start
    By trisket911 in forum Technical
    Last Post: 08-27-2012, 02:37 PM
  5. Checking compression: Kick start vs. Electric
    By shidifen in forum Technical
    Last Post: 02-09-2010, 08:35 PM
