Flat saddle options - Page 2
Flat saddle options
This is a discussion on Flat saddle options within the General forums, part of the Caferacer.net Forums category; You should have left that brace, it was structural. I may be wrong but I think replacing it with a loop of thin wall pipe ...
Results 11 to 20 of 27
Like Tree3Likes
Thread: Flat saddle options
  1. #11
    Mar 2016
    You should have left that brace, it was structural. I may be wrong but I think replacing it with a loop of thin wall pipe at the rear end is more like adding a torsion bar then a brace.
  2. #12
    Quote Originally Posted by alwaysavocado View Post
    ... once I get it running (mostly carb related) ...
    No surprise there with vacuum operated carbs combined with pod filters and little to no back pressure on the exhaust.
    You are going to end up pounding huge volumes of fuel through it just to try and compensate for those mods, that's what everybody else who attempts it seems to do.
  3. #13
    Member alwaysavocado's Avatar
    Sep 2018
    Northern California
    What’s a good fix? I asked the previous owner what was happening , he said the carb on the left (when sitting) would always foul the spark plug pretty fast . Different jets or filters, or swap out the carbs for another style? He also said the floats were probably off. Not sure what route to go for the carbs.
    Ews
    Ews is offline
    Senior Member Ews's Avatar
    Jun 2015
    Lewiston Idaho
    If it is in your budget, I'd get better carbs. There are a lot of good after market carbs out there that will be less maintenance and headache
  6. #15
    The route you go for the carbs is you get a manual and you learn to rebuild carbs. If possible you put the stock airbox on it .
    Mar 2016
    Honda Twins will have a manual.
  8. #17
    Previous owner didn't have a clue what the problem is or he would have fixed it
    Disclaimer: I have zero personal first hand experience modifying that bike, the following is based only on what I have read and I accept no credit or responsibility for these ideas, or your results should you choose to pursue them.
    1) replace the carbs with non-vacuum controlled carburetors and apparently pods directly connected to your carburetor might be made to work reasonably well.
    note: none of these modifications were documented by performance testing to validate their modifications provided a performance improvement over stock.
    or
    2) introduce a tube or velocity stack between the carburetor and the air filter, which is relatively similar to what the original air filter uses.
    repeat: none of these modifications were documented by performance testing to validate their modifications provided a performance improvement over stock.
    The same writers also reported the need for some form of an exhaust system in conjunction with the original CV carbs so as not to kill the motors performance in at least one part of the power band.
    but repeat: none of these modifications were documented by performance testing to validate their modifications actually provided a performance improvement over stock.
  9. #18
    Sep 2018
    Northern California
    Awesome information! Thanks for all the tips so far. I come from a Chevy and Volkswagen background so I am just familiarizing myself with different brands and options for carburetors on bikes. With all my searches and reading that I’ve done the last few days it seems like the Mikuni carb kids keep coming up, certainly not cheap but they sound like they are pretty good carbs. Without getting crazy deep into performance and primarily looking for reliability and obviously without breaking the budget are those good options or is there something a little more economical someone can recommend?
  10. #19
    Mar 2016
    Velocity stacks go between your carbs and the breather to smooth airflow. I can't see your exhaust but it's likely part of the problem. Figure out what made it run like shit, it wasn't because of the carbs. Did you go to Honda Twins forum and get a service manual? Did you look through any of the thousands of threads there specifically on cb350 fuel systems?
  11. #20
    Sep 2018
    Northern California
    Not yet I just got this . It’s all new to me and this is a starting point . I’ve only only old school cars and vespas. I’ll snag a manual for sure , my primary concern is the carbs or like you mentioned the filters or tuning .
  1. Saddle bags
    By Johnsondarcy in forum Gear
    Last Post: 03-21-2016, 11:19 AM
  2. Oldish cafe racer getting back into the saddle
    By Ed9911 in forum NEW MEMBERS READ HERE!
    Last Post: 01-01-2014, 01:46 PM
  3. Honda GB500 dual saddle?
    By sorenlarsen in forum General
    Last Post: 01-25-2011, 02:47 PM
  4. Woo! New saddle
    By tonupoakland in forum General
    Last Post: 08-20-2009, 10:28 AM
  5. Vintage Flat Track school
    By ROSKO in forum Vintage Motorcycle Racing
    Last Post: 04-06-2008, 08:53 AM
