KZ1000 monoshock conversion - Page 2
This is a discussion on KZ1000 monoshock conversion within the General forums, part of the Caferacer.net Forums category; dudes, please tell me part of that lower linkage is not using the the center stand pivots......
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Like Tree1Likes
Thread: KZ1000 monoshock conversion
  1. #11
    Senior Member seanbarney41's Avatar
    Sep 2015
    Kalamazoo, MI.
  2. #12
    Same design but way better executed.
    Unless you smash the dogbone on rocks and it deforms the oil seal, then water gets inside and rusts out the needle bearings.
  3. #13
    jcw
    jcw is offline
    Senior Member jcw's Avatar
    Jul 2015
    chicago burbs
    I recall a couple BMW k1200 r/s bikes having catastrophic rear suspension failures from the needle bearings seizing and the dogbone failing.
    Senior Member Cyorg's Avatar
    May 2014
    I used a BMW swingarm that came with needle rollers (for the swingarm pivots) no idea how many miles were on it, but based on their condition (with no signs of water or lack of grease) , rather than replace the bearings with more of the same, I make up some bronze bushings. Needle rollers would have been ok for the riding I do, but they didn’t leave me with a warm fuzzy feeling.
    "Non urinat in ventum"
  6. #15
    Aug 2012
    grants pass, OREGON, USA.
    Where do I start the Top shockmount has no chance of handling the loads nor does the center stand brackets at the bottom being used for the bottom mount the struts or links are only seeing tension and comp
    That extended swinger is going to.need a shock mounted further rearward
    As it sits it has too much wheel travel to little spring rate to light on damping rate
    Ther top frame rails will buckle no matter what because nothing ,zero had been done to the frame to address the loads
