KZ1000 monoshock conversion
This is a discussion on KZ1000 monoshock conversion within the General forums, part of the Caferacer.net Forums category; Hmm...definitely a "different" approach to fabricating a shock mount. Saw this over on Garage Journal: https://www.garagejournal.com/forum/...postcount=2325...
Results 1 to 10 of 15
Like Tree1Likes
Thread: KZ1000 monoshock conversion
    Sep 2009
    Kansas City
    Name:  Troy KZ1000.01.jpeg
    Name:  Troy KZ1000.02.jpg
    Name:  Troy KZ1000.03.jpg
    that is interesting, esp the part where one of the braces goes right into the backbone leading to the neck.
    jcw likes this.
    Swingarm is long as [email protected]#$% and that lower linkage would be too light duty for a 160 pound trials bike but what do I know :|
    jcw
    jcw is offline
    Senior Member jcw's Avatar
    Jul 2015
    chicago burbs
    He's got a proper linkage set up too.
    If he has the math skills to manually calculate the ratios or inputs it into a suspension program like Tony Foales', it looks like it might be a well done conversion.
    If he just eyeballed it, another fail. I mean changes of linkage length of a cm and less changes the ratio curve significantly.
    I would have triangulated the plate to the side rails, personally. Shorter, stiffer, better structure, imo.
    jcw
    jcw is offline
    Jul 2015
    chicago burbs
    Those linkages if everything lines up properly work only on tension and compression.
    The bolt for my swingarm goes right through the motor, that's what makes my motor a stressed member,
    this one the frame is 100% the stressed member.
    Otherwise how is the suspension design not just a copy of the pro-link suspension with the bolt points moved way far back?
    Senior Member Cyorg's Avatar
    May 2014
    That swingarm has been extended a bunch. Not sure why you’d want to extend it that much unless you’re climbing hills.
    This is an interesting shock mount.
    "Non urinat in ventum"
    Two of these is a way better option to a chunk of aluminum with extra holes drilled in it, given that it is going to wear out, I'd buy 4 right off the start lol
    available at your local farm supply.
    May 2014
    Older Ducati Monster uses a couple of those joints on the rear shock fork. I made a knockoff of that fork and added heim joints to both ends. Makes for accurate adjustment.
    jcw
    jcw is offline
    Jul 2015
    chicago burbs
    these are the side deflectiom plates on the bmw k1300s.
    the plates are similar on my gixxer.
