Mugello, Marquez 65 degree lean angle, Dovizioso 221mph
This is a discussion on Mugello, Marquez 65 degree lean angle, Dovizioso 221mph within the General forums, part of the Caferacer.net Forums category; A couple new Motogp records. Physics says the 65 degree lean angle isn't possible....
Results 1 to 10 of 16
Like Tree11Likes
Thread: Mugello, Marquez 65 degree lean angle, Dovizioso 221mph
    Mar 2016
    Jun 2008
    SE MI, USA.
    Only if you overlook the things that make it possible.
    woodsman likes this.
    -Craig
    jcw
    jcw is offline
    Senior Member jcw's Avatar
    Jul 2015
    chicago burbs
    I've always wondered if there is something special about speed that allows them to lean that far.
    I mean, could I go out to the parking lot and lean 55-60 deg? I want to try...
    Maybe it's the stability of the spinning gyros that makes teetering on and over the edge possible?
    Nov 2014
    Melbourne, Australia
    i'd expect it's the tyres. if they can restrain the centrifugal force trying to throw the thing off the side of the road, you can keep going faster, and to do so you need to lean it more.
    Stephen J likes this.
    Jun 2008
    SE MI, USA.
    If I recall correctly, it has something to do with the way the rubber from the tire interacts with the pavement and how the assumption of a coefficient of friction doesn't accurately model what really happens.
    But, it was a LONG time ago that I was having this discussion with someone who should know, so...
    -Craig
    Senior Member nic579's Avatar
    May 2010
    Great Race!
    Hoofhearted likes this.
    The trick is to not cut your toe nails before a race
    May 2010
    I ended races with the TZ250 with top of the boot at toes worn through. Duct tape was my friend.
    Senior Member 8ball's Avatar
    Nov 2012
    East TN
    Quote Originally Posted by nic579 View Post
    Great Race!
    23 lap slug fest!!!!!
    My GS550 Build Thread
    Senior Member Hoofhearted's Avatar
    Mar 2007
    Riverside, CA, USA.
    I've been at 65 deg. several times when I was racing. Usually it was because I was falling off. Some had the knack. Like Ray McCullough at the Ulster. Maybe not 65 deg. but pretty impressive on skinny Dumlop triangulars.
    jcw, woodsman, nic579 and 1 others like this.
    Don\'t cry because its over. Smile because it happened
