Suzuki GS750 Need some help
This is a discussion on Suzuki GS750 Need some help within the General forums, part of the Caferacer.net Forums category; hi guys, new member. I got a 1983 Suzuki Gs750 that i bought recently off a older man, I have a few questions and could ...
Results 1 to 7 of 7
Like Tree2Likes
  • 2 Post By TrialsRider
Thread: Suzuki GS750 Need some help
    Junior Member Steve.Roll's Avatar
    Jan 2020
    hi guys, new member. I got a 1983 Suzuki Gs750 that i bought recently off a older man, I have a few questions and could use some help. He told me the engine was a strong runner and it just needed a battery and should run fine, however when i put a battery in the bike it doesnt attempt to start. The clutch lever is disconnected currently, do this bikes have a clutch switch? If i jump the starter solenoid, the bike does turn over. Also i think someone tried to wire up tail lights as theres a few lug style connectors close to the battery. Need some help please!
    Also, where is the VIN and serial numbers marked too on the bike, I would like to research it so i know exactly what model I have. I bought the bike without the registration and would like to obtain it. Thanks
    Step one obtain a copy of the owner and service manuals. -> Bingo! https://www.carlsalter.com/suzuki-service-manuals.asp
    Look on the frame near the steering head for the VIN stamp, the only time it is not there is if the steering head is not visible due to body work like on a BMW K bike, then it's stamped elsewhere on the frame.
    "He told me the engine was a strong runner and it just needed a battery and should run fine" he lied that's like 'the bike ran when I put it away', I too have some of those laying around.
    Exuptoy and woodsman like this.
    Have you finished reading the service manual yet? I did :| you have a bone simple motorcycle.
    You said you can get it to crank, so the problem is not the starter (which has carbon brushes inside so it will eventually need fixing.)
    You have breaker points ignition, also bone simple if you are any good with servicing breaker points ignition. Check for spark, if you have no spark on 2 cylinders start there.
    ... zero safety switches showing in the wiring diagram.
    Mar 2016
    Is it in neutral?
    Jan 2020
    Yeah the bike will crank if I short the solenoid as in shorting the + 12v across the terminals with a screwdriver. However If i push the start button as of now nothing happens. The bike is in neutral, Although i think the ignition switch is getting bad on it because sometimes ill turn the key and get no dash lights. Ill take a few pictures of it and the extra cables around the battery that i have no idea what theyre for. I basically got the bike for close to free which is why I don't mind tinkering with it, if it needs major work i'll sell it for parts but hopefully I can figure out the wiring so it runs! Havent had time to tinker with it yet had to fix my truck
    every suzuki I have ever owned has had a neutral safety clutch switch wired to the left lever control. get a manual, look at the wiring diagram, trace the neutral safety switch. Often times people unplug it without realizing that the circuit needs to be closed and a jumper or loop needs to be made and plugged into the harness.
    #7 in the diagram
    What Geeto said and those Suzuki slide style switches are notoriously dodgy.
    Also check if you have a sidestand switch (not sure what year they started putting them on).
