Top speed/ power band CB750 question - Page 3
This is a discussion on Top speed/ power band CB750 question within the General forums, part of the Caferacer.net Forums category; For the oil pan I would. If anything it holds the gasket in place while you are fitting the oil pan and putting it in ...
Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
  1. #21
    For the oil pan I would. If anything it holds the gasket in place while you are fitting the oil pan and putting it in place.
    Your local bike shop should have some variation of hondabond, yamabond, suzukibond, or the generic silicone version of said compound (it is all the same really).
    I usually try to get hondabond if I am working on a honda, but that is because I am uber queer - any of the above will work.
    I will caution you about just going into an autoparts store and getting the sealer that way only because there are so many different types of silicone and they keep them all together in the same place so it is easy to get confused and not get the right one.
  2. #22
    Honda feels that if a gasket needs to have sealer, they will put it on it. That is why some Honda head gaskets have shiny parts on them. That is Honda sealant. I don't use any sealant on any gaskets that do not have oil under pressure, like clutch covers, oil pans and alternator covers. I may use it on head or base gaskets if I am reusing them. I know that I shouldn't reuse head and base gaskets but sometimes on race bikes I've used all my spares or I'm at the track. Plus I am really extra cheap and do it anyway cause I can make it work. I use Coppercoat on the head gasket and Permatex formagasket on the base. Silicone is evil and will cause horrible problems if it gets into oil passages or pumps. If you want to use sealer then use one of the semi-drying like Hondabond, yamabond or Threebond.
    AHRMA 412
  1. cb750 k8 carb question
    By tsr4 in forum Technical
    Last Post: 10-28-2016, 05:00 PM
  2. Enfield speed question
    By Johnmw in forum General
    Last Post: 09-14-2012, 01:27 PM
  3. question on a '73 cb750 - should i buy it?
    By ringading in forum General
    Last Post: 09-17-2009, 07:37 AM
  4. CB750 brace question :
    By Wanker in forum Technical
    Last Post: 02-15-2009, 07:41 AM
  5. quck question about a "band aid"
    By Tim in forum General
    Last Post: 08-26-2008, 10:57 AM
cb550 front sprocket wobble
cb750 dohc power band
cb750 front sprocket wobbles
cb750 power band
cb750 powerband
my rpm gauge on my 72 cb750 quit working
setting dwell cb750
sohc4 cb750 powerband
using hondabond on cb750k
