Severely Disappointed with the 08 250.
This is a discussion on Severely Disappointed with the 08 250. within the General forums, part of the Caferacer.net Forums category; All these years since I bought mine thinking "They're going to redesign it someday and it's going to be AWESOME!" Then I see the comparisons ...
Results 1 to 6 of 6
    KoiHoshi's Avatar
    Jan 2008
    Then I see the comparisons and I'm disappointed. Heavier, less performance (they dumbed it down a tad), different frame and things are "harder to get to" from the experiences I've heard thus far. Not to mention it now costs MORE because of the new fairings. I was planning on buying one.. but now? They ruined it for me. Why in the HELL would you redesign a bike with less performance for MORE money? Sure, it's pretty, I'm sure it appeals to the masses... but the 250 is basically a cult following.
    http://www.yoshimura-rd.com/images/p...um/3523_3_.jpg 2008 stock and then with yoshi pipes
    http://www.twobros.com/Cust_Service/...ex250_2006.pdf 2007 stock and then with two brothers exhaust
    Just some info for the curious.
    The wheelbase is slightly longer, the compression is down slightly, it is heavier. The brakes are barely different. The forks and rake setup are just barely different as well. The wheels are also larger (which may account for some of the additional weight). And obviously per dyno the 08 makes just a hair less hp.
    2008 Kawasaki Ninja 250R Specifications:
    Engine Type Four-stroke, liquid-cooled, DOHC, parallel twin
    Displacement 249 cc
    Bore & Stroke 62.0 x 41.2mm
    Maximum Torque 22 Nm (2.24 kgf/m) 16.2 lb-ft/9,500 rpm
    Compression Ratio 11.6:1
    Carburetor Keihin CVK30 x 2
    Ignition Digital
    Transmission 6-Speed
    Final Drive O-Ring Chain
    Cooling Liquid
    Frame Semi-double cradle, high-tensile steel
    Rake/Trail 26 degrees / 3.2 in.
    Front Tire Size 110/70-17
    Rear Tire Size 130/70-17
    Wheelbase 55.1 in.
    Front Suspension / wheel travel 37mm hydraulic telescopic fork / 4.7 in.
    Rear Suspension / wheel travel Bottom-Link Uni-Trak® with 5-way adjustable preload / 5.1 in.
    Front Brake Type Single 290mm hydraulic disc with two-piston caliper
    Rear Brake Single 220mm petal disc with two-piston caliper
    Fuel Tank Capacity 4.8 gal.
    Seat Height 30.5 in.
    Dry Weight 333 lbs. / 337 lbs. (CA-model)
    Overall length 82.1 in.
    Overall width 28.1 in.
    Overall height 43.7 in.
    2007 Kawasaki Ninja 250R Specifications:
    Engine Type: 4-Stroke, Liquid-Cooled, DOHC, 4 Valve Cylinder Head, Parallel Twin
    Displacement: 248 cc
    Bore & Stroke: 62.0 x 41.2 mm
    Maximum Torque: 18.1 lb-ft @ 10,000 rpm
    Compression Ratio: 12.4:1
    Carburetor: Keihin CVK30 x 2
    Ignition: TCBI with Digital Advance
    Transmission: 6-Speed
    Final Drive: O-Ring Chain
    Rake/Trail: 27°/3.3 in.
    Front Wheel Travel: 5.5 in.
    Rear Wheel Travel: 5.1 in.
    Front Tire Size: 100/80-16
    Rear Tire Size: 130/80-16
    Wheelbase: 55.1 in.
    Front Suspension: 36mm Hydraulic Telescopic Fork
    Rear Suspension: Uni-Trak with Aluminum Linkage
    Front Brake Type: Single 260mm Disc with 2-Piston Caliper
    Rear Brake Type: Single 230mm Disc with 2-Piston Caliper
    Fuel Tank Capacity: 4.8 gal.
    Seat Height: 29.3 in.
    Overall length 80.0 in.
    Overall width 28.0 in.
    Overall height 43.1 in.
    Dry Weight: 304 lb.
    Corse Per Vita,
    -Derek
    Edited by - koihoshi on Feb 02 2008 4:12:34 PM
    Edited by - koihoshi on Feb 02 2008 4:13:34 PM
    Moderator ROSKO's Avatar
    Feb 2005
    I have been mulling it over too. The price isn't really an issue, new one's msrp is like $400- more. Not bad at all. The good points are really good... with the 17" wheels you have many more tire choices, plus it comes with bt-45's out the box. better tires, better brakes w/ wave rotors, better suspension, more mid range torque and better looking. The down side? A little heavier and a tad less hp. It's a tough call. I'd like to hear back from a seasoned ex250 rider on the differences. There hasn't been any real feedback online yet because nobody has finished break-in. The jury is still out.
    BORN TO LURK, FORCED TO WORK.
    www.NYCvinMoto.com
    www.VinMoto.org
    KoiHoshi's Avatar
    Jan 2008
    I have put several thousands of miles on my 05. I love it to death.
    I'd love to get my hands on one and TRY it to see what I think. The specs make me go "BLEH!" though it was never a "fast bike" in the first place. Unfortunately, the one place that would let me try them is no longer around as they went out of business. I'd have to go quite a ways to try out the new 250 at another dealer. Perhaps when it warms up I'll go on a crusade for personal rest of peace on the whole thing.
    Corse Per Vita,
    -Derek
    it may be time to consider a hyosung 250 instead. Hyosung was the south korean engine manufacturer for suzuki who got license to make bikes. The gt650s are actually sv650 engines. their 250s are v-twins (not parallel like the ninja) and they make an even 30hp in GT250R trim. Also their dry weight is 277.8 lbs. Brand new MSRP is $3,700 if you want a solid body color (more if you want graphics or two tone).
    the only downsides I see to the hyosung are that it is oil/air cooled and not water cooled, and that it has a 5 speed gearbox instead of a 6 speed like like the ninja. It is also geared for acceleration so it tops out at around 90mph where as the ninja 250s top speed is slightly north of 100mph. also it is slightly more money than a ninja 250. it also has slightly less torque than the ninja 250 (16 vs 18 lb-ft).
    on the upside it does have an upside down fork, and an adjustable rear shock. It is also a little more than 30 lbs lighter (nothing to sneeze at). All in all I think when you get done with the bikes they are a wash.
    Edited by - geeto67 on Feb 04 2008 07:32:10 AM
    Moderator jbranson's Avatar
    Feb 2004
    , , South Sandwich Islan.
    A six speed compared to a five speed on a high revving low hp 250 is a HUGE....HUGE factor.
    Feb 2005
    there is one more contender... the Yamaha wr250x. 5 valve 250cc thumper with EFI weighing in at 280lbs. The only problems I can forsee are related to driving in a legal manner....
    www.NYCvinMoto.com
    www.VinMoto.org
  1. Disappointed - Charlie's Place....
    By Geeto67 in forum General
    Last Post: 09-16-2009, 08:41 AM
  2. A little disappointed.....
    By leo in forum General
    Last Post: 07-31-2009, 09:28 AM
